  3. Losing connection due to IP address changing
4 Posts 3 Posters 837 Views
    briddellm
    I appears that my IP addresses are changing on some of the student computers. Once I go in and change them on my list, I can see them again. I had the same issue with ITalc but was able to force it to use the MAC address. Is there any way to force Veyon to use the MAC address only and not the IP address?
      Hi @briddellm
      currently we only support connecting with either hostnames (which may be associated with dynamic IP addresses) or fixed IP addresses. There'll be a computer auto-discovery mechanism as a commercial addon later this year 🙂
      • I Offline
        imahfouz
        Has this addon been released? Where can we download it?
        I have the same issue. I added the computer names, mac addresses and ip addresses. But when the ip address changes, I stop seeing the computer. How do I force it to use the computer name/mac address rather than the ip address? Is that a setting I can set somewhere?
        Thanks
          Yes, you can use the Network Discovery add-on, see https://veyon.io/en/addons/#networkdiscovery for more information. You
          can simply download install the add-ons package matching your Veyon version and test the add-on.
