  3. Remote Sound?
Remote Sound?
4 Posts 3 Posters 780 Views 1 Watching
    drubs
    I was wondering if it's possible to play the client's audio on my master computer. I looked for any option in this regard, but couldn't find it.
    Any information is really welcome! Thank you!
    D 1 Reply Last reply
    • D drubs
      drubs
      This post is deleted!
        Hi @drubs
        unfortunately Veyon currently does not have audio forwarding support.
        Tobias
        • I Offline
          ITGuy
          As a workaround for monitoring audio you could install Stream What You Hear onto the client computers.
          http://www.streamwhatyouhear.com/download/
          Use the SWYH HTTP Live Streaming option and a player like Media Player Classic Home Cinema.
          In SWYH settings choose a specific HTTP port and automatically run on log in.
          From the MPC-HC File menu select Open File then enter the client computer streaming URL:
          http://ip-address:port/stream/swyh.mp3 or http://computername:port/stream/swyh.mp3
          Audio playing on the chosen client computer will be heard on the Veyon master computer.
          From a command prompt:
          "C:\Program Files\MPC-HC\mpc-hc64.exe" http://10.62.64.75:5901/stream/swyh.mp3
          "C:\Program Files\MPC-HC\mpc-hc64.exe" http://LABx64075:5901/stream/swyh.mp3
          A suggestion would be to create a folder of player shortcuts on the desktop, one for each client computer either by name or IP.
