Problems VEYON installation
Posts
Posters
738
Views
Hi, I am a teacher, and trying to use VEYON at school. Installation and configuration of Master and Client worked fine. The problem is, that I am unable to see (control) the client computer. We use dynamic IP, so I used the MAC adress. When I try "remote view" from the master to a client, I get this screen inside screen, ... error.  Moving the mouse over the ClientIcon, also shows "not conected"... What's the problem? I can send you a ipconfig -all, or arp -a...
OK. I checked the IP, and they had a mistake. But now, I get a "Autentification error or unable to access". No idea how to make it. I followed the instructions about export public key and import key... Any help? Is there any log file?
