  3. Power On Doesn´t work on Veyon 4.1.4
2 Posts 2 Posters 559 Views 1 Watching
    abrarahsan
    wrote on last edited by abrarahsan
    (Power Off) (Restart) work perfectly but whenever we try to (Power On) doesn´t work.
    Before we were using 4.1.2 after see some posts with the same problem we update to 4.1.4 but the same problem happen, we have configure both with IP ADDRESS and MAC ADDRESS but doesn´t work.
    Can somebody help us to tell how to configure (Power on) on client cumputer. Maybe there is any another configuration we have to done for this function.
    Thanks.
      Does Wake-on-LAN work in general on your computers, i.e. enabled in BIOS / NIC setup? Have you already tried a separate Wake-on-LAN tool? Can you try to disable your firewall temporarily?
