  3. How to reduce image quality and frame rate?
3 Posts 2 Posters 781 Views
  • V Offline
    V Offline
    Vitokhv
    the problem is that the cursor on the client is blinking
    • V Offline
      V Offline
      Vitokhv
      You read?
        You could try to increase the thumbnail update interval as documented at http://docs.veyon.io/en/latest/admin/reference.html#basic-settings
