  3. Need help to configure veyon with command line
2 Posts 1 Posters 448 Views
  • Z Offline
    Z Offline
    zeltron80
    wrote on last edited by zeltron80
    First, the context
    Ubuntu Xenial, many rooms.
    As I explained in another post, I have to use veyon 4.0.4 ubuntu xenial package (issue with LDAP auth on 4.1.x).
    As I manage a lot of rooms, I can't use GUI interface to enter my machines one by one by hand. It' s possible too, that machines change during the year for a lot of reasons, and it would take too much time to do that.
    For all those reasons, I'm trying to find a way to configure all this with scripts.
    I use the command :
    veyon-ctl config get LocalData/NetworkObjects
    to get rooms and computers information, and it works well.
    The idea is to modify this key, and then, use
    veyon-ctl config set LocalData/NetworkObject
    to reconfigure veyon.
    I know exactly how to do this, with bash and python. Actually, I already made the scripts, it's pretty simple :
    Everytime the teacher's computer starts, it reloads veyon's configuration file from a network share. So I just got to modify this file to update every teacher's computers configuration.
    Everytime veyon is installed on a new computer, it modifies this file to add/update its references in the LocalData/NetworkObject key.
    BUT
    The only thing I can't manage is the "UID" parameter (for rooms and computers). I don't know how this parameter is generated.
    It would be a great help for me if someone could explain this process, and where those UIDs are stored.
    (I found the /etx/xdg/Veyon Solutions/Veyon.conf file, but it doesn't help much)
    Thanks for your help
    E.T.
    • Z Offline
      Z Offline
      zeltron80
      Hi again,
      I slept on it, as one says, and I realized there was no problem with UIDs : I just got to generate and include them in the conf.
      Very often, network based softwares work with agents on clients, that sends its information on server, to be "recognized".
      I realised there is no such process in veyon, and that a computer's UID is only present on master, the client doesn't even know it.
      Sorry for that "stupid" question. You can mark as "resolved"
      For the record : I'm discovering Veyon, and I'm really impressed by its possibilities and its fast evolution.
      Thanks for your great job
      E.T.
