  3. Problem for Key
Problem for Key
2 Posts 2 Posters 153 Views
    Astring
    [ERROR] Failed to read the input data file. Please check your access rights.
    [FAILURE]
    veyon-cli.exe authkeys import user/public %source%\user_public_key.pem
      Is the file readable, i.e. can you run e.g. notepad %source%\user_public_key.pem? What happens if you replace the placeholder with a qualified path?
