  3. Veyon for Redhat 8
Veyon for Redhat 8
2 Posts 2 Posters 501 Views
  • G Offline
    G Offline
    glenn-lawrence
    Is there a veyon download that is compatible with redhat 8? I was using the Centos release, but realized that was centos 7, which is what I think was causing some problems.
      Unfortunately we do not have packages for Redhat 8 (since CentOS 8 is EOL) but I would recommend building an RPM file manually as described in the README.md file in the sources.
