Master Disconnects from LAN and have to reboot all student PC's
Hi All
My first post and only installed Veyon yesterday so excuse my ignorance. There are 10 student PC's and one master all connected to the same LAN. I am using public private key authentication. If the Master PC disconnects from the network whilst using Veyon just for a second we have to restart all 10 student PC's to restore connectivity. Is there a better way to re-establish the connection please?
Thanks in advance
GTB -
Hi All
Thanks in advance
GTB@gtb
I have made a bit of progress with this in as much as if i turn the network switch that all devices are connected to off and then back on again, then the student PC's all pop up on the master screen almost immediately. So a good workaround and probably more to do with my network than the Veyon application
