  3. Connection problems with Windows 10 pro.
1 Posts 1 Posters 139 Views
  • J Offline
    J Offline
    jorge
    I am trying to mount Veyon Master for 8 Laptops with Windows 10pro. These are connected by wifi, the master computer is Windows 8 connected to the router by cable. Install everything, create the keys, export the public key to the client computer, but when connecting, a Windows notification arrives: "user Master at host Laptop3 attempted to access this computer but could not authenticate successfully".
    Looking for a solution for this change of master and client. I use the laptop with Windows 10pro for master and the desktop PC with Windows 8 as client and here if there is connectivity, it works fine. Then try to connect a Windows 10pro client laptop to the Windows 10pro master laptop but the same message as above appears.
    Does anyone know how to fix them?
