help using Veyon CLI
i was hoping to get some help using the Veyon CLI
im just looking to deploy a bat file that will import the public key onto the client machines.
i have deployed the key and usually manually import them but i would like to make this a little more easier over a larger amount of PC's
when using
Veyon-cli authkeys
i get the return of
[ERROR] Not enough arguments given - use "authkeys help" for more informationthats great but when i try
veyon-cli "authkeys help"
or
veyon-cli authkeys helpi get the response
is not recognized as an internal or external command,
operable program or batch fileany help appreciated.
when using
Veyon-cli authkeys
i get the return of
or
