  3. Bypass Screen Lock
Bypass Screen Lock
3 Posts 3 Posters 1.4k Views
  • N Offline
    N Offline
    NeeleFraune
    we've been using Veyon at our school for some time now, and we've noticed that the students bypass the computer locks using a second desktop (Win+Tab and then new desktop). This causes problems, especially for younger students. Does anyone know a way to stop this?
    • C Offline
      C Offline
      Carlo
      @NeeleFraune
      Hi, have you tried disabling key combination?
      https://lifehacker.com/disable-disruptive-hotkeys-while-gaming-with-this-scrip-1626902738
      or
      https://learn.microsoft.com/en-us/windows/iot/iot-enterprise/customize/keyboardfilter
      Hope this helps.
      • Y Offline
        Y Offline
        ybgnetman
        wrote on last edited by ybgnetman
        We've noticed this problem too - we thought there should be an option to disable the client keyboard/mouse input whilst you are using remote control.
        The same use case applies to lock mode, but this remote input disable isn't implemented as a function in Veyon.
        The VNC backend should support these functions already - so can the Veyon Client and Master make use of these?
