  3. Mobile laptops and wifi - doesn't work
2 Posts 2 Posters 161 Views
  • L Offline
    L Offline
    Ludo.be
    Good morning.
    I am a new user of the Veyon software.
    My students are using laptops in different classes with different wifi network.
    I tryed to link my computer to theirs with their mac adress but it is not working.
    The objective would be to supervise their work wathever and wherever they or we connect. (all on the same network.
    Is it possible?
    Thanks in advance for your help.
    Ludo
    Belgium
      erict
      I think network discovery addon should be able to partially do that, no ?
      But it doesn't only rely on veyon's conf.
      Your master(s) should be allow to communicate with those wifi networks, which depends on your network conf (infrastructure and master's conf).
      Of course, if laptops are student's personnal computer, I think it's not a good idea to ask them to setup a software on it, which gives you remote access. More than an ethical issue (already sufficient IMHO), there could be a legal problem.
      Regards
      E.T.
