  3. general questions
general questions
2 Posts 2 Posters 985 Views
    Antoine
    hi, i just discover this solution, and i have 2 questions, but i don't see the answers, if you can help me :
    1/ this solution is it free ? (i talk about solutions, not addons)
    2/ can we listen the sound of each pc, if the personne is using a voip phone for example ?
    Thanks for your help,
    Antoine
    M 1 Reply Last reply
    • A Antoine
      Antoine
      Michaelj89
      @Antoine Yes, the core solution is free, as Veyon is open-source, but some advanced features or enterprise support may require additional costs. You can use the main functionalities without paying, but addons or custom integrations might come at a price.
      Regarding audio monitoring, Veyon does not support direct audio listening from remote PCs, including VoIP calls. It primarily focuses on screen monitoring, remote control, and classroom management. If you need to monitor audio, you may have to look for third-party solutions designed for that purpose. Hope this helps!
