  3. Problems with Veyon-Configurator
2 Posts 1 Posters 181 Views
  • J Offline
    J Offline
    juniorfilho
    I use Linux Deepin 23. I installed veyon 4.9 via deb package downloaded from the website, but I can't open veyon-configurator. I always get the message:
    Insufficient Privileges
    Could not start with administrative privileges. Please make sure a sudo-like program is installed for your desktop environment! The program will be run with normal user privileges.
    Is anyone else facing this problem? Has anyone already solved it? How do I solve it?
    • J Offline
      J Offline
      juniorfilho
      veyon-configurator
      QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
      Logger: "/tmp/VeyonConfigurator.log" is a symlink and will not be written to for security reasons
      2024-12-06T10:23:11.405: [ERR] CryptoCore: failed to decrypt password!
      2024-12-06T10:23:11.416: [ERR] LinuxPlatformPlugin: Received signal 11
      2024-12-06T10:23:11.417: [ERR] BACKTRACE:
      /lib/x86_64-linux-gnu/libc.so.6(+0x3d1a0) [0x7ffb2de591a0]
      /usr/bin/veyon-configurator(+0x1d945) [0x56319b741945]
      /usr/bin/veyon-configurator(+0x22d70) [0x56319b746d70]
      /usr/bin/veyon-configurator(+0x129a1) [0x56319b7369a1]
      /lib/x86_64-linux-gnu/libc.so.6(+0x27b8a) [0x7ffb2de43b8a]
      /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7ffb2de43c45]
      /usr/bin/veyon-configurator(+0x134b1) [0x56319b7374b1]
      2024-12-06T10:23:11.417: [CRIT] Aborting due to severe error
