veyon-server doesn' start and no connection on Port 11100
Posts
Posters
506
Views
Watching
Hi.
We use veyon in a computer room. So far it has worked flawlessly with Ubuntu 18.04.
Now we changed to Ubuntu 20.04 and since then the teacher can't see the clients any more. Maybe it's a problem with wayland (new default?)So far I tried:
Teacher-Computer:systemctl status veyon.service ā veyon.service - Veyon Service Loaded: loaded (/lib/systemd/system/veyon.service; enabled; vendor preset: enabled) Active: active (running) since Tue 2025-01-21 08:51:42 CET; 35min ago telnet localhost 11100 Trying 127.0.0.1... Connected to localhost. Escape character is '^]'. RFB 003.008 veyon-server QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root' 2025-01-21T09:48:57.645: [ERR] FeatureWorkerManager: can't listen on localhost! 2025-01-21T09:48:57.728: [ERR] main: Failed to start server KLDAP: connection closed! ps aux |grep veyon /usr/bin/veyon-service /usr/bin/veyon-server /usr/bin/veyon-worker {...} < everything seems to be OK?!But on a Students-Computer (Cloned -- so it's an identic installation):
systemctl status veyon.service ā veyon.service - Veyon Service Loaded: loaded (/lib/systemd/system/veyon.service; enabled; vendor preset: enabled) Active: active (running) since Tue 2025-01-21 09:20:16 CET; 23min ago telnet localhost 11100 Trying 127.0.0.1... telnet: Unable to connect to remote host: Connection refused veyon-server status qt.qpa.xcb: could not connect to display qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found. This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem. Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb. ps aux |grep veyon root 387007 0.0 0.2 326184 33144 ? SLsl 09:20 0:00 /usr/bin/veyon-service root 387013 0.0 0.2 481748 34432 ? Sl 09:20 0:00 /usr/bin/veyon-serverI think that the veyon-server doesn't start correctly on the Students-Clients. But why?
At the moment nobody is logged it. It was just a test via ssh / bashAny ideas?
Thank you!P.S.: dpkg -l |grep veyon
ii veyon 4.9.1-2~jammy -
Today I tried to run (as root):
veyon-server startThe error message looks like this:
veyon-server start QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root' 22/01/2025 12:12:34 passing arg to libvncserver: -rfbport 22/01/2025 12:12:34 passing arg to libvncserver: 11200 22/01/2025 12:12:34 passing arg to libvncserver: -rfbportv6 22/01/2025 12:12:34 passing arg to libvncserver: 11200 22/01/2025 12:12:34 passing arg to libvncserver: -passwd 22/01/2025 12:12:34 x11vnc version: 4.9.0 lastmod: 2019-01-05 pid: 10067 22/01/2025 12:12:34 Using X display :0 22/01/2025 12:12:34 rootwin: 0x496 reswin: 0xe00001 dpy: 0x8c0089b0 22/01/2025 12:12:34 22/01/2025 12:12:34 ------------------ USEFUL INFORMATION ------------------ 22/01/2025 12:12:34 X DAMAGE available on display, using it for polling hints. 22/01/2025 12:12:34 To disable this behavior use: '-noxdamage' 22/01/2025 12:12:34 22/01/2025 12:12:34 Most compositing window managers like 'compiz' or 'beryl' 22/01/2025 12:12:34 cause X DAMAGE to fail, and so you may not see any screen 22/01/2025 12:12:34 updates via VNC. Either disable 'compiz' (recommended) or 22/01/2025 12:12:34 supply the x11vnc '-noxdamage' command line option. 22/01/2025 12:12:34 X COMPOSITE available on display, using it for window polling. 22/01/2025 12:12:34 To disable this behavior use: '-noxcomposite' 22/01/2025 12:12:34 22/01/2025 12:12:34 Wireframing: -wireframe mode is in effect for window moves. 22/01/2025 12:12:34 If this yields undesired behavior (poor response, painting 22/01/2025 12:12:34 errors, etc) it may be disabled: 22/01/2025 12:12:34 - use '-nowf' to disable wireframing completely. 22/01/2025 12:12:34 - use '-nowcr' to disable the Copy Rectangle after the 22/01/2025 12:12:34 moved window is released in the new position. 22/01/2025 12:12:34 Also see the -help entry for tuning parameters. 22/01/2025 12:12:34 You can press 3 Alt_L's (Left "Alt" key) in a row to 22/01/2025 12:12:34 repaint the screen, also see the -fixscreen option for 22/01/2025 12:12:34 periodic repaints. 22/01/2025 12:12:34 22/01/2025 12:12:34 XFIXES available on display, resetting cursor mode 22/01/2025 12:12:34 to: '-cursor most'. 22/01/2025 12:12:34 to disable this behavior use: '-cursor arrow' 22/01/2025 12:12:34 or '-noxfixes'. 22/01/2025 12:12:34 using XFIXES for cursor drawing. 22/01/2025 12:12:34 GrabServer control via XTEST. 22/01/2025 12:12:34 22/01/2025 12:12:34 Scroll Detection: -scrollcopyrect mode is in effect to 22/01/2025 12:12:34 use RECORD extension to try to detect scrolling windows 22/01/2025 12:12:34 (induced by either user keystroke or mouse input). 22/01/2025 12:12:34 If this yields undesired behavior (poor response, painting 22/01/2025 12:12:34 errors, etc) it may be disabled via: '-noscr' 22/01/2025 12:12:34 Also see the -help entry for tuning parameters. 22/01/2025 12:12:34 You can press 3 Alt_L's (Left "Alt" key) in a row to 22/01/2025 12:12:34 repaint the screen, also see the -fixscreen option for 22/01/2025 12:12:34 periodic repaints. 22/01/2025 12:12:34 22/01/2025 12:12:34 XKEYBOARD: 22/01/2025 12:12:34 Switching to -xkb mode to recover these keysyms: 22/01/2025 12:12:34 xkb noxkb Keysym ("X" means present) 22/01/2025 12:12:34 --- ----- ----------------------------- 22/01/2025 12:12:34 X 0x40 at 22/01/2025 12:12:34 X 0x5b bracketleft 22/01/2025 12:12:34 X 0x5d bracketright 22/01/2025 12:12:34 X 0x7b braceleft 22/01/2025 12:12:34 X 0x7d braceright 22/01/2025 12:12:34 X 0x7c bar 22/01/2025 12:12:34 X 0x5c backslash 22/01/2025 12:12:34 22/01/2025 12:12:34 If this makes the key mapping worse you can 22/01/2025 12:12:34 disable it with the "-noxkb" option. 22/01/2025 12:12:34 22/01/2025 12:12:34 22/01/2025 12:12:34 X FBPM extension not supported. Xlib: extension "DPMS" missing on display ":0". 22/01/2025 12:12:34 X display is not capable of DPMS. 22/01/2025 12:12:34 -------------------------------------------------------- 22/01/2025 12:12:34 22/01/2025 12:12:34 Default visual ID: 0x3b 22/01/2025 12:12:34 Read initial data from X display into framebuffer. 22/01/2025 12:12:34 initialize_xdisplay_fb: \*\*\* fb creation failed: 0x0 try: 1 22/01/2025 12:12:35 Default visual ID: 0x3b 22/01/2025 12:12:35 Read initial data from X display into framebuffer. 22/01/2025 12:12:35 initialize_xdisplay_fb: \*\*\* fb creation failed: 0x0 try: 2 22/01/2025 12:12:35 Default visual ID: 0x3b 22/01/2025 12:12:35 Read initial data from X display into framebuffer. 22/01/2025 12:12:35 initialize_xdisplay_fb: \*\*\* fb creation failed: 0x0 try: 3 22/01/2025 12:12:35 Default visual ID: 0x3b 22/01/2025 12:12:35 Read initial data from X display into framebuffer. 22/01/2025 12:12:35 initialize_xdisplay_fb: \*\*\* fb creation failed: 0x0 try: 4 22/01/2025 12:12:35 Default visual ID: 0x3b 22/01/2025 12:12:35 Read initial data from X display into framebuffer. 22/01/2025 12:12:35 initialize_xdisplay_fb: \*\*\* fb creation failed: 0x0 try: 5 2025-01-22T12:12:35.793: \[ERR\] LinuxPlatformPlugin: Received signal 11 2025-01-22T12:12:35.795: \[ERR\] BACKTRACE: /lib/x86_64-linux-gnu/libc.so.6(+0x42520) \[0x7a7df4442520\] /usr/lib/x86_64-linux-gnu/veyon/builtin-x11vnc-server.so(+0x7fc00) \[0x7a7ddc67fc00\] /usr/lib/x86_64-linux-gnu/veyon/builtin-x11vnc-server.so(+0x40450) \[0x7a7ddc640450\] /usr/lib/x86_64-linux-gnu/veyon/builtin-x11vnc-server.so(+0x145e5) \[0x7a7ddc6145e5\] veyon-server(+0xa8f1) \[0x5802944ff8f1\] /lib/x86_64-linux-gnu/libQt5Core.so.5(+0xccca1) \[0x7a7df4cccca1\] /lib/x86_64-linux-gnu/libc.so.6(+0x94ac3) \[0x7a7df4494ac3\] /lib/x86_64-linux-gnu/libc.so.6(+0x126850) \[0x7a7df4526850\] 2025-01-22T12:12:35.795: \[CRIT\] Aborting due to severe error Abgebrochen
