ARM X86 How to build,Help!!!!!!
General Discussion
Posts
Posters
503
Views
Can there be an ARM x86 architecture Veyon?
I have an unofficial build v4.9.7 which covers all the supported x86_64 Linux distros. (Sorry I cannot post a link because I don't have enough reputation, please replace [dot] to "." manually)
Download: github[dot]com/IronBlood/veyon/releases/tag/v4.9.7-arm.6
Build log: github[dot]com/IronBlood/veyon/actions/runs/18685442374
The patch: github[dot]com/veyon/veyon/compare/v4.9.7...IronBlood:veyon:dev/v4.9.7-arm
Disclaimer: I built these packages as a friend of mine would like to use veyon, but I personally know nothing about veyon, nor had I test these binaries.
