  3. wireless network: malfunction block internet
2 Posts 1 Posters 136 Views
  • N Offline
    N Offline
    nicola.autiero
    ciao, io have a problem.
    I have a mixed wired and wireless network. When I use Veyon, I block the internet connection:
    • Wired computers: the internet connection remains blocked.
    • Wireless computers: after a while, they automatically reconnect.
      Why?
    All the computers in question have a static IP address.
    • N Offline
      N Offline
      nicola.autiero
      SOLVED:
      solved the problem.
      need to disable the virtual network card created by Virtual Box.
