  3. Teacher-side Multi-Display Issue
1 Posts 1 Posters 110 Views
  • S Offline
    S Offline
    sylar1986
    Subject: Screen Broadcasting Shows Black Screen with Blue Circle on Student Clients in Dual Monitor Setup
    Hello Veyon Community,
    I am experiencing an issue with screen broadcasting in a dual-monitor classroom environment and would appreciate any help.
    My Setup:
    • Teacher Computer: Running Veyon Teacher.
    • Monitors:
      1. A drawing tablet (1080p resolution) used for lecturing and writing. I want to broadcast only this screen to students.
      2. A regular monitor used to run Veyon Master for monitoring student screens during class.
    The Problem:
    Whenever I start a screen broadcast from the teacher computer, the student clients receive a black screen with a blue loading circle in the center. The broadcast is also extremely laggy and unusable.
    Current Workaround:
    To make it work, I have to connect the drawing tablet to a separate student computer. I then use the teacher computer to broadcast that specific student's screen to all other students. This method works correctly, but it is not an ideal solution.
    My Question:
    Is it technically impossible to achieve this (broadcasting one specific screen directly from a dual-monitor teacher computer) within Veyon? I would like to understand if this is a known limitation, a configuration issue, or a potential bug.
    Any insights, suggestions, or configuration guidance would be greatly appreciated.
    Thank you!
