  3. avoir plusieurs ordinateur maitre (masters) sur un ordinateur client
4 Posts 2 Posters 907 Views
  • U Offline
    U Offline
    ulrick
    Bonjour ,
    j'aimerais savoir si il est possible de mettre plusieurs clé publique (key) de différent poste maitre sur un poste client.
    Merci d'avance
    • U Offline
      U Offline
      ulrick
      @ulrick said in avoir plusieurs ordinateur maitre (masters) sur un ordinateur client:
      Bonjour ,
      Merci d'avance
      Hello ,
      I would like to know if it is possible to put several key public of different post master on a post client.
      thank you in advance
        Hi @ulrick
        in Veyon 4.1 you'll be able to use multiple keys for different user roles - check out one of the preview versions available at our download page. We'll also continue to improve multi-key support in the future (e.g. bindings for access control).
        U 1 Reply Last reply
          Hi @ulrick
          U Offline
          U Offline
          ulrick
          @tobydox thank you!
