Problems with remote control/view when the user is not interacting
Hi!
 First of all; thanks for this software! It's very useful.
 Currently I'm facing this issue;
 When the student computer is not being used (unlocked on the desktop or unlocked) and I try to remote view or remote control on the master computer it only shows a black screen. I've attached a video that shows exactly what happens.
 The moment the student interacts (opens a program) the image appears right away.
 Here's a link to a video showing exactly what happens in case my explanation wasn't clear enough Any clue what could be causing this issue? Thanks in advanced!
This is kind of what I am having but in my case the black screen is permanent in view or control mode. Everything else works, mouse moves on remote PC but I can't see anything but black. Doesn't matter if client user interacts or not. Did you resolve the issue? Feels like there is a problem with the 4.1.0.
This is kind of what I am having but in my case the black screen is permanent in view or control mode. Everything else works, mouse moves on remote PC but I can't see anything but black. Doesn't matter if client user interacts or not. Did you resolve the issue? Feels like there is a problem with the 4.1.0. @blakecarrington
 Haven't solved the issue yet. Tried using ultraVNC, increasing the memory limit to 512 MB and still no luck
