  3. Installation problems
9 Posts 3 Posters 751 Views
    Tuisku
    I'm trying to install the teachers computer, after I add the class and computers, when I press Apply - it does not get saved - the button just becomes gray, it is a formatted computer - just WIN 10 installed. what can be the problem? (tried few times)
      Hello @Tuisku
      if you press "Apply" in Veyon Configurator the configuration is saved and the button becomes gray until you change the configuration again. After saving you can open Veyon Master to open the actual user program.
        Tuisku
        I tried - but it doesn't recognize the client computers, I was told that there should be 3 programs -
        in the teacher computer I only get the first one
          Tuisku
          I could not start the service it stay on "stopped "
            Tuisku
            Sharing
            • The problem was solved once I changed the interface language to English
              That's interesting! Which language would you use/configure normally?
                Tuisku
                I tried in Hebrew
                • C Offline
                  C Offline
                  CeoSoares
                  the option transfer files and shut down, not is working.
                  can you help me please?
                    @Tuisku
                    there was indeed an old bug which always made the Veyon Server crash with language set to Hebrew. This has been fixed in the code and a temporary test release is available at https://github.com/veyon/veyon/releases/download/v4.2.1/veyon-4.2.1.26-win64-setup.exe - feel free to test and report back!
                    @CeoSoares
                    Please do not hijack threads with different topics 😉 You can open a new thread or create a detailled bug report in our bug tracker at https://github.com/veyon/veyon/issues
