Trouble in Class with 32 AND 64 bit Win
in a class I have 10 PCs with win 7 32 bit and 10 PC with win10 64 bit. Is it impossible to install Veyond Master on the teacher's PC to see all 20 PCs?
Hi @norgepaolo
mixing Veyon installations is no problem (you can even monitor Linux computers from a Windows master) as long as you're running the same release series (i.e. version 4.2.x on all computers) -
@tobydox said in Trouble in Class with 32 AND 64 bit Win:
Hi @norgepaolo
mixing Veyon installations is no problem (you can even monitor Linux computers from a Windows master) as long as you're running the same release series (i.e. version 4.2.x on all computers)thanks, so the problem could be another .. Veyon Master with 64 bit only sees PCs with veyon 64 bit clients. Veyon Master 32 bit sees only PCs with veyon 32 bit client. Some idea? I can see PCs with the same system as the master normally, those with different operating systems as red, and those not turned on as gray
Solved. Must be authenticated with key and not with logon
