  3. Problem adding computers/locations using veyon-cli
2 Posts 2 Posters 423 Views
    muneutrino
    hi there,
    thank you for this good program. The test-installation of version 4.2.1. is working great with windows 10.
    But i have a problem adding new computers and locations. The veyon-cli tools list the entries of the configuration tool, but changes using "veyon-cli networkobjects add ..." wont be displayed at the configuration tool. There are just displayed using "veyon-cli networkobjects dump"
    I wonder, what's the problem.
    thx
      Hi @muneutrino
      the computer objects probably have been created in the root folder i.e. Parent UUID is "00000000-0000-0000-0000-000000000000". This happens if you do not specify a parent for a computer when creating it (parent=room - can be specified by either UUID or name). Please specify all arguments as shown by the example printed by veyon-cli networkobjects help add. If you do not want to set a MAC address simply specify "" as 3rd argument. Afterwards dump should show
      You can remove the orphaned objects via veyon-cli networkobjecty remove UUID.
