Veyon device RDP issue
Similar topic has been posted in January without any replays.
i have an issue on client computer where i installed recently Veyon.
i have connected to that device once through veyon Master but after that RDP has issues of getting second connection.
First RDP connection to that device is fine and working.
After you close the RDP and try to re-connect then it is not possible until you restart the device.
Any helpful advice or solution would be great.(PS. writing in this forum is awfully difficult because capital letters cutting off half of the text)
@FailedStorme Please try again with Veyon 4.2.3 which includes multi-session support which should also work for multiple RDP sessions. The Server instances will listen at the network ports 11101, 11102 etc.
Hello! It looks like you're interested in this conversation, but you don't have an account yet.
Getting fed up of having to scroll through the same posts each visit? When you register for an account, you'll always come back to exactly where you were before, and choose to be notified of new replies (either via email, or push notification). You'll also be able to save bookmarks and upvote posts to show your appreciation to other community members.
With your input, this post could be even better 💗
Register Login
