  3. Nothing except Remote View/Control works
4 Posts 2 Posters 315 Views 1 Watching
  • W Offline
    W Offline
    w0lly
    Everything appears to be setup and working correctly - Veyon 4.2.2, testing on two Win10 machines, got keys/specific user groups working don't mind which I use. Computers show up and Remote View/Control works, can't get any other features to work at all.
    Any ideas?
      Which update interval have you configured for Veyon Master?
      • W Offline
        W Offline
        w0lly
        What I believe is default - 1000ms.
        I can also add that the newer version I am testing here is working perfectly to control PCs in our ICT Suite that are on an old version 4.0.* and running Windows 8.1.
          That's an interesting observation! Are you using the key file authentication? Can you try to change the update interval to a lower value? Is any kind of access control configured?
