Veyon Users - Need a little help with setup
Hello everyone,,
I've finally got the program working on a few test machines using LDAP but I can't find some info for deploying the software and settings I would like.I'm deploying it via SCCM: veyon-4.0.4.0-win64-setup.exe /S
It's silent installing but I would like to only install the service, not the master on lab machines. Is there a switch to do this?
I would also like to have the tray icon hid on install but don't see anywhere to set that option or deploy a config for them.
Any help with this would be greatly appreciated!
Hi @Helsinki
first of all welcome to the Veyon Community!I'd strongly advice to use the most recent version of Veyon, i.e. 4.2.4 or newer. The 4.0.x series is not supported any longer.
According to https://docs.veyon.io/en/latest/admin/installation.html#examples you can pass
/NoMaster
to the installer which will only install the core and service components.The tray icon can be hidden through the appropriate setting as described at https://docs.veyon.io/en/latest/admin/reference.html#refservicegeneral
Hello everyone,,
@Helsinki said in Veyon Users - Need a little help with setup:
Hello everyone,,
It's silent installing but I would like to only install the service, not the master on lab machines. Is there a switch to do this?I would also like to have the tray icon hid on install but don't see anywhere to set that option or deploy a config for them.
Thankyou my issue has been solved...
