  3. Veyon Users - Need a little help with setup
veyon
2 Posts 2 Posters 814 Views 1 Watching
    DavidJones
    I've finally got the program working on a few test machines using LDAP but I can't find some info for deploying the software and settings I would like.
    I'm deploying it via SCCM: veyon-4.0.4.0-win64-setup.exe /S
    It's silent installing but I would like to only install the service, not the master on lab machines. Is there a switch to do this?
    I would also like to have the tray icon hid on install but don't see anywhere to set that option or deploy a config for them.
    Any help with this would be greatly appreciated!
      retroisbest
      Hi there,
      I use these switches
      /S /NoMaster /NoStartMenuFolder
      (i also deploy a config to the clients using /ApplyConfig=\pathtomyconfig\MyConfig.json)
      hope this helps
