  • Brite
  3. Fullscreen demo and Window demo resolution scaling issues
1 Posts 1 Posters 615 Views 1 Watching
    retroisbest
    wrote on last edited by retroisbest
    Hi there,
    We have an issue when using Veyon master 4.2.4 with the demo functionality.
    (Clients are also on 4.2.4)
    When we try and broadcast a demo to our clients the clients only receive a very small portion of the window.veyon1.PNG
    3/4 of the screen is black while the last quarter displays the window of the application we want to show.
    The same results occur with fullscreen and window demo
    Changing the Veyon master resolution changes the amount viewable in that last quarter area.
    Has anybody else experienced this?
    The Veyon master is running at 1680 x 1050
    Thanks!👍
    ** UPDATE **
    If i turn off enable multi monitor support for the Veyon master i now get full screen and window demo working correctly, it would be nice if we could choose which display on a multi monitor Veyon master would be the broadcast display (with multi monitor support enabled display number 2 is used, but has scaling issues, if multi monitor support is disabled display 3 is used and seems to be working correctly for the client, the only issue i see here is by default any clients I connect to will also use display 3 resulting in a demo window full of duplicated window type effect)
    Hello! It looks like you're interested in this conversation, but you don't have an account yet.
    Getting fed up of having to scroll through the same posts each visit? When you register for an account, you'll always come back to exactly where you were before, and choose to be notified of new replies (either via email, or push notification). You'll also be able to save bookmarks and upvote posts to show your appreciation to other community members.
    With your input, this post could be even better 💗
    Register Login
