How to switch on my computers by using "on" buttom
You need to enable Wake-On-Lan. This allows the computer be turned on by other devices such as the Veyon master application. Wake-On-Lan allows the computer to be woken up even when it is in full shutdown. Having it enabled keeps the network Interface card on even when the computer is powered off. To enable this you need to do two things; -
Enter setup mode in your BIOS and find the "enable Wake-On-Lan" option. It may be under a different name such as "Remote Power On".
On your Windows operating system, go to Device Manager, expand Network adapters tab, right click your network adapter and go to properties, then go to power management and tick all the boxes. (If visible) go to the advanced tab for the network adapter and enable "wake on magic packet".
 if you followed all of these instructions, the computer should now be able to be woken up by the Veyon master application.
