  • avoir plusieurs ordinateur maitre (masters) sur un ordinateur client
    U
    @tobydox thank you!
  • problems with the use of Veyon
    Which version of Veyon are you running? Which VNC software do you have installed? Can you take a look at the log files in C:\Windows\Temp\Veyon*log ?
  • AD user and password storage
    Hi @Ben-Ronlund you're right that in Veyon 4.1 all passwords (also including the LDAP bind password) are stored encrypted in the local configuration. Once you upgrade to Veyon 4.1 and modify the configuration they get encrypted automatically (besides other configuration updates). This means you should save your configuration before upgrading to 4.1 as reverting back to 4.0 will make problems.
  • Download Veyon in a Rapsberry PI (Debian)
    Unfortunately Veyon currently is not available for Raspberry Pi (armel/armhf/arm64). You can however build packages on your RPI on your own as described in our README file. We might provide binary packages for RPI in the future as well.
  • Veyon locks, reboots or stops all computers at once
    Hi @SamGreff theoretically you can omit the master computer from the configuration with the drawback that auto-discovery of current room will not work. In your case you can enable the setting "Hide local computer" in the Master configuration page in Veyon Configurator. This should hide the master computer while functioning regularly.
  • Master Disconnects from LAN and have to reboot all student PC's
    OK I'll have a look whether we can improve the connection timeout settings.
  • Signal Lag
    Problem #1. If they are on the same network, then try disabling your firewall. If the connection is successful, try to open ports Problem #2. Check energy settings to try to solve the sleep mode, it could be an option
  • Global User Configuration (for Veyon Master)
    Thanks for fixing that in a future release. The message box shouldn't be a problem (and could be a indicator that it works). Custom positions is not that important - to fix the zoom level will be enough.
