  • Could NOT find LZO
    lzo qca not find lzo couldnotfindlzo
    @tobydox windows 10 64bit visual studio 2017 community edition
  • A client shows as multiple machines in the classroom on the Master
    Can you try again with Veyon 4.1.0?
  • Veyon - Experiencing With High Latency On Highend Machines
    Does upgrading to Veyon 4.1.0 help?
  • Importing CSVs with through configurator
    3k Views
    @joki issue is fixed in Veyon 4.1 final - thanks for reporting and discussing in our issue tracker!
  • Old italc versions
    You can find old downloads the the official release page at https://github.com/iTALC/italc/releases - however we strongly advise against using it due to potential security issues. If there's something which is stopping you from using Veyon, please tell us! We'll try to find a solution
  • Installation Opensuse Leap 42.3 Fehlermeldung
    Hello @Technikus as this is an international English speaking forum I'll reply in English - I hope this is fine to you! It's correct that our packages are not signed yet but you should still be able to use them. The final 4.1 release also has a few fixes related to RPM packaging - I invite you to test this release.
  • Veyon Notification
    @tobydox That is fantastic thanks for the update!!!
  • Veyon and se3
    3k Views
    Any other ideas ? Thanks
  • WOL bug on beta version 4.0.91
    Hi @Joel thank you for your feedback! We indeed had a bug in the wake-on-lan module which could lead to application crashes. It has been fixed in 4.1 RC (4.0.92) and will be fixed in upcoming 4.0.8 release as well.
  • I control a computer and visualize
    Hi @ulrick which version of Veyon are you using? Which operating system and version is running on master and client computers? Do your keyboards have special function buttons?
  • UID in Json
    @hugo_alva You can generate UUIDs on your own. Take care to use identical UUIDs for ParentUUID. Besides that I recommend to manage everything through Veyon Configurator. Starting with Veyon 4.1 you can also modify computer and room information at the command line, see https://veyon.io/blog/2018/04/24/network-object-management-cli/ for details
  • Issues in Linux Machines - Pre-releases
    Thanks for the feedback! We'll do more testing with Ubuntu 16.04 in preparation of the final 4.1 release. I'll let you know once we have bug fixes for the problems mentioned.
  • No idea how to add clients to the master
    Welcome to Veyon! I suggest to watch a video on Veyon such as https://www.youtube.com/watch?v=0YimKRncnuw - afterwards you should have an idea of how to get get Veyon running. Feel free to ask specific questions if you're stuck at a certain step.
  • error trying to hook up 4 machines to my master account
    @bcorn02 Veyon only runs on Windows 7 or higher. XP is not supported any longer, sorry
  • Screen's not displaying
    @dwhitespire You will need to either add computers manually through the Veyon Configurator or set up LDAP/AD integration to make Veyon fetch classroom and computer information from your LDAP/AD. See our manual at docs.veyon.io for more information
  • LDAP
    @Micky219 thanks for testing the pre-releases! @ulrick did you manage to get LDAP integration up and running?
  • Install Veyon without Master Application
    It usually doesn't harm to have the Veyon Master installed on clients as a properly set up installation won't allow non-teachers to use it anyway. However you can manually delete /usr/bin/veyon-master and /usr/share/applications/veyon-master.desktop in order to remove Veyon Master completely.
  • Master not seeing another master
    master
    You should be able to see other master computers if authentication is set up properly Are you using key file authentication or logon authentication?
  • Connecting to computers with Dynamic IP
    a.rubioA
    @Micky219 thanks for your response. I have tried computer address/IP indicating hostname (without IP and MAC) and it seems to be working...
  • Possible to run scripts/commands on login screen?
    Hi Tobydox Thank you very much for your reply, that makes sense I see what you mean. That sounds good! Many thanks for the great software!
