  • No visual, veyon
    Thanks for reporting! Veyon 4.1.3 will include a fix which trims spaces and newlines from host and MAC addresses automatically when editing them through Veyon Configurator.
  • 4.1.2 version on ubuntu 18.04 ppa?
    Sorry for the delay of the Ubuntu packages.
  • Remote login users
    Hello @joffrey welcome to Veyon! Remote login is currently not implemented but is planned for future releases, likely in 2019.
  • Multiples Masters
    One master has to generate the public and private keys. Then copy the private key to another master.
  • computers changing state every second on master
    It works, thanks!
  • Computers going in and out of service
    Issue should be fixed in Veyon 4.1.2 - please give it a try
    Hello! Welcome to Veyon! The public key should always be readable by everyone, so use a group such as "users " here.
  • Can I change thumbnail size?
    looks like thumbnails resize nicely when I click on the Veyon notification icon twice. The first click minimizes the Veyon Master window; second click restores the Master window and the moniotored thumbnails get resized. Oh, I also just discovered the slider and buttons along the bottom of the window - that's what I was looking for!
  • Problem with Raspberry
  • Problems VEYON installation
    @alberto OK. Now I make it. The problem was "use VNC tool" in the Service Tab. Question closed.
  • More Masters
  • How to compile Veyon on windows platform?
    I'm trying to use vcpkg to build the required libraries and then use vs 2017(cmake) with vcpkg to generate the vs project.
  • Limiting access for teachers to specific rooms
    The "Perform Access control at program start" option makes the Master application check whether the teacher is allowed to access computers at all. It's an additional check for convenience (which can lead to false positives, that's why you should try to disable it for the time being) but not strictly necessary as the actual access control is performed on client computers so that only authorized users will be granted access. If the option is disabled, anybody can start the Master but still will only be able to access clients he's really allowed to access.
  • Can I use Veyon WITHOUT LDAP?
    @Tarloth you don't need LDAP to run Veyon. You can configure rooms and computers using the builtin network object directory. The only difference to iTALC is that room and computer management is done through the Veyon Configurator and not inside Veyon Master any longer.
  • Built-in (UltraVNC) password?
    Hi @mikep345678 the builtin passwort is generated randomly at runtime so it can't be used from the outside world. You can however install UltraVNC in parallel, set a password and configure Veyon to use this existing UltraVNC server. Best regards Tobias
    Which directories are the plugin installed in? Please make sure they're located in /usr/lib64/veyon or pass a proper value to cmake via -DCMAKE_INSTALL_LIBDIR=/usr/....
  • New to Veyon. I have no clue how to use it
    just install it on master as master and on client without master checklist. for password request in every enter the veyon master, you can enter configuration and set authentication on GENERAL with method: key file authentication (same method for master and client). if you have no idea, you can look at this video
  • Student/Staff access to Configurator
    Hi @mikep345678 thanks for your feedback and useful suggestion! I just added a new parameter "/NoStartMenuFolder" to the installer so starting from Veyon 4.1.2 (likely to be released this week) you can pass this parameter to the Veyon installer in your deployment software. Best regards Tobias
  • Virtuelle Desktops in Windows 10 beobachten oder abschalten
    Lieber Tobias, vielen Dank für deine Antwort. Ich antworte nochmal auf deutsch um diesen Thread abzuschließen aber werde zukünftig natürlich Englisch nutzen. Derzeit nutzen wir in der Tat noch ITalc aber würden lieber früher als später auf Veyon wechseln. Genau solche Möglichkeiten in Veyon beschleunigen das aber natürlich Ich melde mich. Beste Grüße Michel
