1.1k Topics 2.8k Posts
  • mass login does not work
    21
    4k Views
    @Carlo That solution isn't good in my case, because I'm not always present in the laboratory and I can't always log the students.
  • AD Setup Assistance
    DC=domainName,DC=lan Where the domain is "domainName.lan"
  • Maquinas com acesso via Remote Desktop não exibem a tela
  • Demo Mode not working after a while
  • Can connect but get only a blue screen
    The headless VNC plugin will always shot a blue screen only. You have to use the x11vnc backend. If you switched from Wayland to X11, it should work. If not, what errors can you see in the VeyonServer log files?
  • Problema funzione Login windows su computer remoti
    @Tommaso said in Problema funzione Login windows su computer remoti: Buon giorno ho un laboratorio con 30 pc windows 11, nella procedura di login remoto soltanto alcuni pc ricevono tutta la sequenza di caratteri nel campo Utente e Password, gli altri non compilano completamente ma mancano diversi caratteri, ho già provato ad aumentare nel configuratore il campo (Simulato l'intervallo di pressione dei tasti) fino al massimo possibile ma la situazione non cambia, Qualcuno mi può aiutare questa funzione mi è essenziale per la gestino del laboratorio. Grazie. ~translation from google~ Good morning, I have a laboratory with 30 Windows 11 PCs, in the remote login procedure only some PCs receive the entire sequence of characters in the User and Password field, the others do not fill in completely but several characters are missing, I have already tried to increase the field in the configurator (Simulated key press interval) up to the maximum possible but the situation does not change. Can anyone help me? This function is essential for me to manage the laboratory.
  • WoL does not work - LDAP Basic
  • How to make students don't see the Veyon window
    Presumably your projector is just duplicating your current monitor, correct? Set your projector to EXTEND your desktop rather than duplicate. Then you can show whatever you need to on the projector "monitor" and keep things you do not want students to see on your actual monitor on your desk.
  • Log in function Ubuntu
  • Veyon 4.8.1 not all classroom's PC became visible after reboot command.
    12
    4k Views
    Hi @fra-sa @esaurel In one lab, I finished updating all my clients to Veyon 4.8.2, and for some students, the issue is still present. At this very moment, the lab is wired with both the Windows 10 x64 master and student computers connected at 1 GB/s. I opened an issue on github here: https://github.com/veyon/veyon/issues/895. In the meantime, hitting F5 refreshes the correct student status. Have a good day.
  • VEYON 4.5.7.0
    Good morning, Thank you for your reply
  • Login Linux - Multiple Desktop Environments
  • VEYON 4.5.0.0 with DHCP
    Veyon depends heavily on static addresses. There are options to make use of some weird techiques to make it work with dynamic addreses, not worth the headache though. Static is definitely the main solution.
  • Installation without administrator rights.
    https://silentinstallhq.com/veyon-silent-install-how-to-guide/
  • Veyon 4.5.7 removing needing IP feature for remote access
