  • Active Directory / search in security group missing some devices
    Hi, Yep. Literally all the computers are in the same groups / same OU / same tree. They all were visible last major version, and after the update only about half are now visible within Veyon if I flag Veyon to use the AD as the backend for rooms. I've seen this before a few years ago, but it seemed to fix itself after they got updated at some point. That is why I'm not sure if this is a Veyon caching or timeout issue, or something else entirely. When starting veyon with AD as its room / backend the bootup does take quite a while, I am assuming its running through the LDAP/AD search.
  • Cannot lock screens if students not logged in (AD)
  • No authentication key files error
  • Web Interface
  • Problem with 1 client
  • Laboratório em DHCP
  • install venoy in debian on x86
  • Problem with WOL
    Hi, Have you tried to turn off fast startup on Windows? https://www.howtogeek.com/856514/how-to-disable-fast-startup-on-windows-10/ Have you checked that in Bios you turn off all kinds of "deep sleep" mode or Ethernet power saving? Have you checked that on Windows settings / network screen, under network profile type, private mode is selected? Also, I remember that in some Lenovo PCs, if the system was shut down manually, it doesn't wake up by WOL anymore. It has to be shut down by Veyon command to have WOL to work. Hope this helps.
  • Veyon & Windows10 KB5028166
    No...I guess you've updated cliens and server ? Now, knowing my own case, It's amazing that in a full micro$oft environment, you've also this problem.
  • Téléchargement Veyon 4.8.1
    Bonjour, Essayez de passer par là : [https://github.com/veyon/veyon/releases/](link url) Cela fonctionne de mon côté.
  • Problemas na visualização após atualizar
  • Ouverture session W11 sur
    The issue has been fixed with Veyon 4.8.1
  • VEYON with W10+GCPW?
    Hi, we also have implemented GCPW in our labs. At the moment we have no preblems on clients, but we are missing the login feature becuse windows is set up to try the login with GCPW while our needs would be to login on pcs through Veyon with a local user account. This seems to be impossible right now.
  • Deny access to Veyon if a user is not listed in a local group
  • Some computers asks for Perm keys insted of Pem keys
  • Veyon in RDP Enviroment
  • Veyon Master doesnt find Clients after new Image
  • Change Folder Transfert
  • Poste clients bloque
    Hello, J'ai le même soucis ! Préviens quand tu as une solution s'il te plait !
  • Veyon Freeze watch 10 PC
