  • Authentication failed or access denied
  • Upgrading multiple machines
    This can be easily done with PSTools from Microsoft and a batch script or PowerShell. I use the following to manually remotely install veyon and the security keys when the GPO installer doesn't work for any reason. You can replace line 1 with a call to a list of computers rather than specifying a single computer if that fits your needs better. SET /p computer="enter computername:" XCOPY "\\networklocation\veyon-4.7.5.0-win64-setup.exe" "\\%computer%\C$\" /e /h /y XCOPY "\\networklocation\UserConfig.json" "\\%computer%\C$\" /e /h /y XCOPY "\\networklocation\veyon\Veyon\*.*" "\\%computer%\C$\ProgramData\Veyon\" /e /h /y timeout /t 5 CD "C:\PSTools\" psexec64 \\%computer% C:\veyon-4.7.5.0-win64-setup.exe /S /ApplyConfig=C:\UserConfig.json /NoMaster
  • Veyon on Linux
  • Solo un escritorio
  • Veyon 4.7.5 classroom's PC doesn't all show up once rebooted.
    Hi, after the reboot command when all my calssroom PCs shows the desktop if I hit "F5" then I can get back them all visible in veyon master. This is only a small issue but wasn't present in 4.7.4 release. Have a good day.
  • change Password veyon Master
  • Veyon with azure Intune
    -1 Votes
  • Veyon master login
  • Mix Windows and Linux Machines
  • Effet mirroir désagréable / unpleasant mirror effect
    You could easily minimize the demo window and control the computer as normal.
  • Red monitor on all ICT PC
    Hi, can you please check the permissions on the key files? Did you export the private key from one Veyon Master to the other one?
  • Wake-On-LAN set, Power On doesn't kick...
    Sorry for the late repply... Disabling "fast startup" did the trick for me. The replacing of dash with colons didn't seem a good idea, cause for the Lenovo's it worked like that. Only the Dell's were the reluctant ones, so it seemed to be a station configuration problem.
  • Failed to build Veyon form source code (Could NOT find LibVNCClient)
    @lmoellendorf Can you try passing -DWITH_PCH=OFF to CMake? Which version of CMake are you using?
  • first installation failed - no client visible
    @PowerBauer What operating system? Key authentication? Do you assign it by hostname or IP address? If you are using key authentication, have you set two keys on the master that you want to control, and only the public key on the master? Try to set it up based on that, that's what I looked at first. link text
  • PCs not appearing
  • STUCK AT LOADING WHEN DOING DEMO ON CLIENT
  • configuration
  • message d'erreur , help
  • configurer veyon 4
