  • Remote control and indicators
  • veyon-ctl networkobjects import bug ?
  • Veyon Latency on Presentation Mode
  • Services not working collectively
    services rooms terminals
  • veyon not working puppy linux Tahrpup 6.0.5?
    K
    I have successfully installed it but when I click veyon master or configurator nothing happens What is the solution?
  • Shift Key not working
    Thanks for providing the investigations and sharing the workaround! While scrutinizing the issue I spotted a problem in the build system leading to relevant x11vnc features such as the keyboard extension not being enabled at compile time. This will be fixed in 4.1.6.
  • Remote login?
    Unfortunately we have to postpone this feature in order to get everything else done for 4.2.
  • Cursor change while using demo
    Welcome to Veyon! Unfortunately it's currently not possible. We could implement this through professional services. Please contact support@veyon.io this could be an option for you.
  • Is access control working?
    Restricting access to a group such as teacher is the way to go so there seems to be a problem with the system or Veyon configuration. I assume the teacher users are member of a teacher group on both master and all client computers? Can you run getent group teacher and post the output here?
  • I can't cross compile for windows
    Please switch to the 4.1 branch or install cyrus-sasl-mingw-w64.
    Have you solved the problem by now? Please see https://docs.veyon.io/en/latest/admin/configuration.html#authentication for more information on how to set up authentication in Veyon.
  • Dienst Probleme
    Ich arbeite mit windows 7 64bit
  • Ldap auth issue with veyon-master on Ubuntu 16.04
    10
    3k Views
    Hi Tobias, I just described a similar issue here: [https://github.com/veyon/veyon/issues/455](link url) Thanks in advance, Julius
  • LDAP auth issue with veyon 4.1.4.0-win64
    Ok, As this rooms PCs are windows PCs, joined to an Active Directory, I used AD, and auth works fine (because my organization's AD master did it with me). I guess I needed some more configuration in env and advanced parameters to make it work. I didn't have to do that with linux, as my PCs were LDAP auth based, and in access control, I just had to choose "default (local groups and users)", and not LDAP, as I have to with AD joined windows PCs. I didn't test further ldap conf, as I finally don't need it Answer this post could help other people with the same question, though
  • Integration tests LDAP fails
    Below you can find the config output (I changed domain settings: BaseDN, BindDN, BindPassword and ServerHost): { "AccessControl": { "AccessControlRulesProcessingEnabled": "false", "AccessRestrictedToUserGroups": "false", "AuthorizedUserGroups": [ ], "DomainGroupsEnabled": true, "UserGroupsBackend": "{6f0a491e-c1c6-4338-8244-f823b0bf8670}" }, "Authentication": { "Method": 0, "PrivateKeyBaseDir": "%GLOBALAPPDATA%\keys\private", "PublicKeyBaseDir": "%GLOBALAPPDATA%\keys\public" }, "BuiltinDirectory": { "NetworkObjects": { "JsonStoreArray": [ ] } }, "Core": { "InstallationID": "dfa175a6-76ee-4967-8d40-eb4d56737502", "PluginVersions": { "JsonStoreObject": { "{14bacaaa-ebe5-449c-b881-5b382f952571}": "1.1", "{1b08265b-348f-4978-acaa-45d4f6b90bd9}": "1.1", "{1baa01e0-02d6-4494-a766-788f5b225991}": "1.1", "{1bdb0d1c-f8eb-4d21-a093-d555a10f3975}": "1.1", "{2917cdeb-ac13-4099-8715-20368254a367}": "1.1", "{2ad98ccb-e9a5-43ef-8c4c-876ac5efbcb1}": "1.1", "{387a0c43-1355-4ff6-9e1f-d098e9ce5127}": "1.1", "{39d7a07f-94db-4912-aa1a-c4df8aee3879}": "1.1", "{4122e8ca-b617-4e36-b851-8e050ed2d82e}": "1.1", "{4790bad8-4c56-40d5-8361-099a68f0c24b}": "1.1", "{67dfc1c1-8f37-4539-a298-16e74e34fd8b}": "1.1", "{6f0a491e-c1c6-4338-8244-f823b0bf8670}": "1.1", "{85f6c631-e75a-4c78-8cb2-a7f3f502015a}": "1.1", "{8ae6668b-9c12-4b29-9bfc-ff89f6604164}": "1.1", "{a54ee018-42bf-4569-90c7-0d8470125ccf}": "1.1", "{b47bcae0-24ff-4bf5-869c-484d64af5c4c}": "1.1", "{ee322521-f4fb-482d-b082-82a79003afa7}": "1.1" } } }, "Demo": { "FramebufferUpdateInterval": "100", "KeyFrameInterval": "10", "MemoryLimit": "128" }, "Directories": { "Screenshots": "%APPDATA%\Screenshots", "UserConfiguration": "%APPDATA%\Config" }, "ExternalVncServer": { "ServerPort": "5900" }, "LDAP": { "BaseDN": "DC=mydomain,DC=local", "BindDN": "mydomain\Veyon", "BindPassword": "passwordxxx", "ComputerGroupTree": "", "ComputerHostNameAsFQDN": "false", "ComputerHostNameAttribute": "cn", "ComputerRoomMembersByContainer": "true", "ComputerTree": "OU=PcLokalen", "GroupMemberAttribute": "memberOf", "GroupTree": "OU=Leerkrachten", "QueryNamingContext": "false", "RecursiveSearchOperations": "true", "ServerHost": "mydomain.local", "ServerPort": "389", "UseBindCredentials": "true", "UserLoginAttribute": "sAMAccountName", "UserTree": "OU=Leerkrachten" }, "Logging": { "LogFileDirectory": "$TEMP", "LogFileRotationCount": 10, "LogFileRotationEnabled": false, "LogFileSizeLimit": 100, "LogFileSizeLimitEnabled": false, "LogLevel": 4, "LogToStdErr": true, "LogToSystem": false }, "Master": { "ComputerMonitoringBackgroundColor": "#ffffff", "ComputerMonitoringUpdateInterval": 1000 }, "Network": { "DemoServerPort": 11400, "FeatureWorkerManagerPort": 11300, "FirewallExceptionEnabled": "1", "PrimaryServicePort": 11100, "VncServerPort": 11200 }, "NetworkObjectDirectory": { "UpdateInterval": 60 }, "Service": { "Autostart": true, "FailedAuthenticationNotifications": true, "HideTrayIcon": "true", "RemoteConnectionNotifications": false, "SoftwareSASEnabled": "1" }, "UI": { "ApplicationName": "", "Language": "English - American English (en_US)" }, "UltraVNC": { "CaptureLayeredWindows": "true", "Configured": "true", "LowAccuracy": "true", "PollFullScreen": "true" } }
  • Windows 10: Lock screen can be swiped away
    Yes, there's a configuration: "Disable the Swipe Feature of Windows 10" For Windows 10 users with a touch-enabled device, it is possible to enter Task View by swiping left from the edge of the screen. To stop this from happening, you can disable this swipe feature by Windows group policy: Computer Configuration > Administrative Templates > Windows Components > Edge UI ("Rand-UI" in German versions)
  • Service Start/Stop Buttons Grayed Out(Linuxmint)
    O
    Using Linuxmint 19 Tara and XFCE desktop. I don't know what to examine but I uploaded the log files in my google drive, here is the link to it. veyon_logs.zip
  • Authentication failure
    Welcome to Veyon! First of all please consult our troubleshooting guide at https://docs.veyon.io/en/latest/admin/troubleshooting.html Can you see thumbnails of the clients in Veyon Master?
  • View client's dual screen
    I suspect there's an issue with the new desktop duplication engine. You can try to stop the service, remove ddengine.dll / ddengine64.dll and restart the computer. Are you able to see the second screen of this client afterwards?
  • Method for UUID generation ?
    Hi, Sorry, I was too busy to go back to veyon install this last days. Coming back to it, today, I fixed my "problem" : In fact, my .json file was malformed. But, as veyon-ctl returned "OK" message whan I imported it, I didn't suspect that. Now, I fixed it, and it works well. For the record, I have no problem generating UUID with python or even bash, using the following commands : # bash : uuid=$(uuidgen) # python : import uuid newUid = "{" + str(uuid.uuid4()) + "}" I have now a working veyon installation for all my rooms. Every new PC automatically sends its informations to veyon conf (ip, Mac, hostname, UUID and room). Thank you for your help and your great job developping veyon. It's a powerful and really usefull software for education.
