  • Bug in veyon-ctl networkobjects import
    This is indeed an insufficiency in the import command. I just added the missing support for importing an optional object type column. It will be part of Veyon 4.2 and maybe we'll also backport it to future 4.1 releases.
  • Lock all Veyon client from Veyon master from a batchfile ?
    Hello Martin, making all features in Veyon Master accessible through the command line as well is one of our long-term goals. Until then the only thing you can try is to modify the source code such that specific hotkeys are assigned to buttons in the toolbar. I can offer commercial services to get this done for you - please write an email to support@veyon.io. Best regards Tobias
    Please check the permissions on the key files in /etc/veyon/keys/* - you can change the group allowed to read the private key easily using Veyon Configurator -> Authentication keys -> Set access group
  • Creating Password for Veyon Master
    Welcome to Veyon! Have you already read http://docs.veyon.io/en/latest/admin/configuration.html#authentication ? It explains the basics concerning authentication methods. You have to switch the method from logon to keyfile authentication if you want to use it (http://docs.veyon.io/en/latest/admin/reference.html#authentication). If not, you have to make sure to have identical accounts on all computers so you use your normal teacher account for Veyon Master logon.
    Yes please open a bug report so we can deal with that issue in detail.
  • greyed out client machines on the Master
    Welcome to Veyon! If the machines are greyed out they can't be reached by the Master at all. If computers are shown in red they are reachable via ping but not the Veyon Service i.e. no service running or authentication problems. Did you follow the troubleshooting instructions at http://docs.veyon.io/en/latest/admin/troubleshooting.html#computers-can-t-be-accessed ?
  • Veyon 4.1.3 Master Keyboard & mouse not working
    Uninstalling and rebooting should help
  • Complete Full Name/Display Name doesn't display in thumbnail caption
    Thank you for your feedback! We recently improved this in the current development branch so this will be fixed in 4.2. The full name will be displayed properly. May be we'll also backport the change to 4.1.x.
  • Deactivate live user screen in Veyon Master
    @fred Sorry for the late answer. I was on vacation the last days. Yes that´s it. The Veyon Master should be able to lock or unlock a Computer (Veyon Client) without being able to see what the connected user ist doing.
  • No password encryption with veyon-ctl?
    Okidoki. => https://github.com/veyon/veyon/issues/448
  • Need help to configure veyon with command line
    Hi again, I slept on it, as one says, and I realized there was no problem with UIDs : I just got to generate and include them in the conf. Very often, network based softwares work with agents on clients, that sends its information on server, to be "recognized". I realised there is no such process in veyon, and that a computer's UID is only present on master, the client doesn't even know it. Sorry for that "stupid" question. You can mark as "resolved" For the record : I'm discovering Veyon, and I'm really impressed by its possibilities and its fast evolution. Thanks for your great job E.T.
  • Power On Doesn´t work on Veyon 4.1.4
    Does Wake-on-LAN work in general on your computers, i.e. enabled in BIOS / NIC setup? Have you already tried a separate Wake-on-LAN tool? Can you try to disable your firewall temporarily?
  • School district blocks port for demo...
    Yes I double checked that. I also telnet the port and its not active thats how I concluded it was blocked. Is there another port that it might work on or is that the only port the service runs on?
  • Power On Option in v4.1.2 Not Working
    12
    5k Views
    @tobydox I just updated to version 4.1.4. indeed the problem was solved. Thank you!!
  • Can't boot client pc
    @yasser WOL needs the MAC addresses of the PCs to work. So, you have to supply that info in the configuration.
  • Some applications "flashing" after installing the Veyon
    Which version of Veyon are you using? You can try to disable capturing of layered windows in the configurator in the VNC server settings (select builtin VNC server if not selected) within the Service page.
  • How to protect configuration?
    Welcome to the Veyon forum! If users have admin privileges they usually can change any setting of any application so of course this applies to Veyon too Without admin privileges you can neither run Veyon Configurator nor change the settings in the registry.
  • Pop over on remote control?
    Today I worked on improving this so in upcoming 4.1.5 release the toolbar only appears after a delay of about 500 ms and the animation for appearing/disappearing is much faster now so everything should be much more usable now. A test build (4.1.4.10) is available at https://github.com/veyon/veyon/releases/download/v4.1.4/veyon-4.1.4.10-win64-setup.exe If you like the improvements please consider to make a donation to the Veyon project, see https://veyon.io/get-involved/ for details
  • Drop-down menu bar on remote control is annoying!
  • Problem "list all groups of a user" Veyon 4.1.4 x64
    Hello I launched a test in a room of my school and it seems to be OK thank you for your work some suggestions for devolppement: features of italc that were useful: when several rooms were set up, we could choose directly a room to display in one click, [image: 1539350203310-a7f416af-7c9f-4785-af01-d8aca106576a-image.png] When a click held on a thumbnail image of a computer, an enlarged vision of the screen was proposed. Good luck and keep it up Fred
