  • lock users web screen
  • Active Directory Integration
  • Transfert de fichier à partir des postes Client
  • Problème de "démo" d'un pc client vers tous les autres pcs clients.
    @RNETuband Bonjour Effectivement avec le bouton de la barre horizontale du haut cela fonctionne, mais pas en faisant clique droit sur la vignette d'ordinateur a diffuser Fred
  • help using Veyon CLI
    @Da33a Hello, check out the manual here: https://docs.veyon.io/en/latest/admin/cli.html for importing a public key, do: veyon-cli authkeys import key_name/public "C:\path\to\key.pem" if you're importing a private key, change public to private
  • Ubuntu 22.04, password login or user switching, doesn't work.
  • istemci bilgisayarlara bağlanamama sorunu
  • Bug mode demo righ clic Veyon V4.7.4
  • VPN PC can't start
  • Can't connect to PC
    connect location computers
    The website says 4.7.4 is stable. I have tried it in school and still can't see my device but I may not be setting it up correctly. How do you get devices into Locations and Computers. And where would I get an older version of the software please?
  • Layout of computers
  • An error occurs when dragging the contents of a cell
    The only workaround I can find is to stop the Veyon service. This appears to be a bug.
  • students access teacher clipboard
    @Barreira I'm pretty sure it's bad code. There's a post on github about this too, and I posted earlier on this forum as well. So far no responses at all. It's definitely a security issue, and interferes with Excel.
  • Pressing Russian keys is not transmitted during remote control
    @bonny I can confirm that changing languages doesn't work OK with Greek. I have Windows 10 and the latest version of Veyon installed. When changing language to Greek, usually nothing transfers from my master PC to the client. Sometimes, I have seen it sending strange characters. And the usual shortcut to change languages (Alt+Shift) doesn't work properly. I resort to using copy-paste to send Greek.
  • Windows 11 - 22H2 update & Veyon
  • Authentication with Domain not functioning
    @WCGSTech Hello If you use a certificate for SSL authentication it is possible that the certificate has expired, you must renew the certificate with the same key. Fred
  • Veyon launch application variables in path?
  • Veyon Config teacher desktop
  • "Wake on Lan" function doesn't work properly
    @vinicius-souza Here I do it like this: I link the mac and ips in the settings list, in the bios, it depends on the motherboard model, you need to activate S4 S5 and an option called ErP will work.
  • How to remove shortcut to Run Program.
    @tobydox Thank you very much for your information, it worked. Thanks.
