@RNETuband
Bonjour
Effectivement avec le bouton de la barre horizontale du haut cela fonctionne, mais pas en faisant clique droit sur la vignette d'ordinateur a diffuser
Fred
@Da33a
check out the manual here: https://docs.veyon.io/en/latest/admin/cli.html
for importing a public key, do:
veyon-cli authkeys import key_name/public "C:\path\to\key.pem"
if you're importing a private key, change public to private
The website says 4.7.4 is stable. I have tried it in school and still can't see my device but I may not be setting it up correctly. How do you get devices into Locations and Computers. And where would I get an older version of the software please?
@Barreira I'm pretty sure it's bad code. There's a post on github about this too, and I posted earlier on this forum as well.
So far no responses at all. It's definitely a security issue, and interferes with Excel.
@bonny I can confirm that changing languages doesn't work OK with Greek. I have Windows 10 and the latest version of Veyon installed. When changing language to Greek, usually nothing transfers from my master PC to the client. Sometimes, I have seen it sending strange characters. And the usual shortcut to change languages (Alt+Shift) doesn't work properly.
I resort to using copy-paste to send Greek.
@WCGSTech
If you use a certificate for SSL authentication it is possible that the certificate has expired, you must renew the certificate with the same key.
Fred
