  • Full uninstall of Veyon
    After uninstalling, there may be leftovers in C:\ProgramData\Veyon as well as the user's AppData directory (folder "Veyon" in Local or Roaming). The computer list is stored in the registry, so make sure to remove HKLM\Software\Veyon Solutions.
  • LDAP/AD configuration problem
    Hello, Please ignore my previous message. I think it's simply a wrong message All is fine, the AD connection is correct Best regards
  • sending files and login to client
  • Keystrokes - Copy/Paste
    An error occurs when dragging the contents of a cell (see screenshot) [image: 1646053988958-%D1%81%D0%BD%D0%B8%D0%BC%D0%BE%D0%BA.png]
  • screen lock
    I am a teacher, and i have the same problem. Are there any new cognitions?
  • Program service
    It helped, thank you!
  • veyon-server doesn't start on login-screen
    21
    3k Views
    Hello, I am struggling to get veyon-server to start up automaically at the login screen of Ubuntu 20.04 before any user logs in. I am using the lightdm Display Manager and latest veyon from the ubuntu ppa. We have the ubuntu Desktop Environment for local use and the xfce Desktop Environment for use via RDP. So, once I am inside any user session and run the "veyon-server" command from a terminal, the veyon server starts and establishes a proper connection with the veyon master. Before and after that, I just see the orange screen... I have searched quite a while now and found several related posts to this topic, but this seems to be the newest one. Please tell me if I should post any logs or where I could check proper configuration. Thank you in advance. [image: 1644590495609-veyon-l%C3%A4uft-nicht.png]
    Hello All ! I solved my problem in a non-elegant way. I wiped the teacher s disk with an old image. W10 1803. Reinstalled veyon and it worked. Dunno Why. Thanks for your support anyway.
  • Session Mode - Deployment Option?
  • "the key name contains invalid characters"
    @tobydox how am i to this exactly as i have the same challenge?
  • TAB-navigation misbehaviour
  • Run program - Video Editor
  • constant reconnect to clients
  • Keyboards Locking Since Updating to 4.7
  • WOL issue
    Does the network card stay powered (blinking lights), after the system has shutdown? If not, there might be something in the network drivers settings still missing to enable WOL.
  • Veyon Server stopped when LDAP user is logged in
    Hello, Ok, I found a (not totally satisfying) workaround : In /etc/xdg/autostart/ directory, I create a file veyon.desktop with : [Desktop Entry] Encoding=UTF-8 Name=veyon Comment=Lancer veyon Exec=veyon-server Terminal=false Type=Application in it. It is then able to launch the veyon server without problem, I am then able to see and control the machine when a LDAP user is logged in. It is not totally satisfying as as it is launched by the user itself, it can also be killed by them. Beside the fact that they don't nowadays know that they can kill the server and how they can kill it, I am sure that my pupils will one day know it. So I'd like to make them unable to stop the server. Preceding the command by sudo (using the line "Exec=sudo veyon-server" instead of the one in the file) and making the users being able to sudo it in sudoers file does not work because the superuser cannot launch apps that deals with X11 session (surely I don't know how) ... Is there a way to launch veyon-server by root without problem ? I suppose that it is the veyon-service's job (but not working in my case). Thanks
  • Master shuts down when trying to connect to another PC
    Can you try with Veyon 4.7.1 again and report back if it still crashes?
  • RDP Connections
    You have to change the service configuration (on the target machine) so that it uses Active session mode. This will make the Veyon Service launch the Veyon Server for the currently active session, no matter if it's a console or an RDP session. If you require support for multiple RDP sessions, consider activating the Multi session mode and using the NetworkDiscovery add-on to see all (even dynamically changing) sessions in Veyon Master.
  • Have to Restart Service When New User Logs In - Linux Mint
    @mscdaddy30 EDIT: So I figured out how to solve this problem! I installed Veyon via the apt command from the repository and this version had the issue with the service not staying between login sessions. Once I downloaded the .deb file from the website and installed it, the problem went away! The only criticism I have is that there is not a way to remove the "master" portion of the install. Fortunately, the Master that shows up in the start menu requires elevated privileges so the kids cannot access it.
  • How to compile Veyon on windows platform?
    @nishizhen1234 How to compile vs project? I found It requires many dependencies
