  • Problems with same username in master and client machines
  • Veyon running - Ubuntu
  • Logon Authetication issue for non Admin users
    H
    I have the same issue, when I'm not launching Master without admin rights, I'm told that I don't have access to this network. Launch with administrator rights - just fine. Using LDAP and LDAP tests for access are all OK.
  • Disable group control?
  • Client does not appear on the Veyon Master - Wifi
  • AWS setup
  • Can VEYON PORTABLE OR as a AP for WinPE
  • The most simple setup?
    Simply pick a computer (yours maybe) that will be the lead "Master" and install the appropriate version per your OS (32bit/64bit) using all the default settings. Run the same installer on every client/student computer but uncheck the box Veyon Master box during install. Take not of the computer's name and the MAC number. They all need to be able to communicate so it's ideal if they're all on the same domain. On the Master computer, open Veyon Configurator and click Locations & Computers. If you have multiple locations, like many buildings on a college campus, you create locations on the left side, like you may use folders in File Explorer. On the right side you add the client computers for each location. Click apply and you're done. There are other security settings, LDAP settings and things you can adjust as needed for your environment.
  • Flickering issue
  • Runtime error
    12
    4k Views
    I am having this same issue. I used Veyon 4.4.1 and now I get the C++ Runtime error. The master PC is Windows 7.
  • Application dialog boxes do not render (display only white)
  • Accept connection?
    Hi.. Apologies for the delay in getting back to you. I'm afraid that I don't use the group member aspect, so can't really help with that one. Here are grabs of my config: [image: 1594980838069-access04.png] [image: 1594980837973-access03.png] [image: 1594980837862-access02.png] [image: 1594980837753-access01.png]
  • veyon-cli.exe networkobjects import bug?
    The line ending issue has been fixed in 4.4.1 (no more duplicate line endings + proper CRLF line endings on Windows). Thank you for sharing your findings here!
  • Veyon master Windows doesn't see rdp connections
    In fact, it seems commands like C:\Program Files\Veyon\veyon-service.exe restart have absolutly no effect. I tried with service stop (and server too) on the client, and it changes anything in veyon master : the client is still here and responding. It can explain why my tests don't work... What am I missing ?... E.T.
  • No User Logged In
  • Access Control Rule breaks demo
    Stranger and stranger The connection notification goes away if the end user clicks the OK/close button. On the previous version of Veyon which I did my initial tests on - the connection notification would reappear if the pupil clicked the OK/close button on the notification.
  • Prompting to connect to Master PC when running Master?
    Gah! Ignore me.. That didn't work. I'd mistakenly unticked the "show notification when an unathorized.." box I'm just going to roll with it for now. I'd still like to know how to stop it remembering my previously connected clients, though. At the moment, it looks like I'm going to have to replace the shortcut for Master with a script which deletes the per-user settings file and then runs Master.. Not ideal.
  • About the slow connecting speed of new version 4.4.0
    I'm not currently seeing this with a new install of 4.4.0. Is it perhaps worth trying to wipe your settings on a pupil PC, and then re-import settings/key exported from a newly installed 4.4.0? Disclaimer - I haven't upgraded from any previous versions, and my testing is still very recent and limited. Cheers, Gerard
  • Access Control - groups within groups
    Sounds like a perfect solution!
