1.0k Topics 2.7k Posts
  • Flickering issue
  • Runtime error
    12
    4k Views
    I am having this same issue. I used Veyon 4.4.1 and now I get the C++ Runtime error. The master PC is Windows 7.
  • Application dialog boxes do not render (display only white)
  • Accept connection?
    Hi.. Apologies for the delay in getting back to you. I'm afraid that I don't use the group member aspect, so can't really help with that one. Here are grabs of my config: [image: 1594980838069-access04.png] [image: 1594980837973-access03.png] [image: 1594980837862-access02.png] [image: 1594980837753-access01.png]
  • veyon-cli.exe networkobjects import bug?
    The line ending issue has been fixed in 4.4.1 (no more duplicate line endings + proper CRLF line endings on Windows). Thank you for sharing your findings here!
  • Veyon master Windows doesn't see rdp connections
    In fact, it seems commands like C:\Program Files\Veyon\veyon-service.exe restart have absolutly no effect. I tried with service stop (and server too) on the client, and it changes anything in veyon master : the client is still here and responding. It can explain why my tests don't work... What am I missing ?... E.T.
  • No User Logged In
  • Access Control Rule breaks demo
    Stranger and stranger The connection notification goes away if the end user clicks the OK/close button. On the previous version of Veyon which I did my initial tests on - the connection notification would reappear if the pupil clicked the OK/close button on the notification.
  • Prompting to connect to Master PC when running Master?
    Gah! Ignore me.. That didn't work. I'd mistakenly unticked the "show notification when an unathorized.." box I'm just going to roll with it for now. I'd still like to know how to stop it remembering my previously connected clients, though. At the moment, it looks like I'm going to have to replace the shortcut for Master with a script which deletes the per-user settings file and then runs Master.. Not ideal.
  • About the slow connecting speed of new version 4.4.0
    I'm not currently seeing this with a new install of 4.4.0. Is it perhaps worth trying to wipe your settings on a pupil PC, and then re-import settings/key exported from a newly installed 4.4.0? Disclaimer - I haven't upgraded from any previous versions, and my testing is still very recent and limited. Cheers, Gerard
  • Access Control - groups within groups
    Sounds like a perfect solution!
  • Also How do I choose monitors
    And that is realy frustrating Any fix for that ?
  • VEYON in a virtual environment
    vdi rdp virtual desktop remote desktop
    10
    3k Views
    @tobydox Hello tobydox I have created an environment variable in the operating system with a value equal to 2 SET VEYON_SESSION_ID = 2 And also in the veyon-client environment. veyon-cli config set Service/VEYON_SESSION_ID 2 My session ID is two QUERY SESSION SESSION NAME USER NAME ID STATE services 0 Desc rdp-tcp # 2 administrator 2 Active console 3 Conn rdp-tcp 65536 Listen And in no case have I managed to make the screen that shows to the students the session in which the teacher works. I have also test with the new version of Veyon 4.4.0 I would like to remind you that both the students and the teacher are working on their own virtual desktop connected by RDP, that is, they are all in session 2 of their own virtual desktop.
  • problem while installing clients
    Are you running Windows 10? 32 or 64 bit?
  • Configuration of Veyon Master to view activities on client computers
    The documentation on multi session mode at https://docs.veyon.io/en/latest/admin/reference.html#refmultisessionmode has been improved to reflect information on how to access RDP sessions in general. Also the (currently very basic) RDP support will be further improved in future Veyon releases.
  • Error When Trying to Download
    Hi Justin, yes this is probably a problem with your browser or has been a temporary issue. The download links work well here. Best regards Tobias
  • Veyon cause remote desktop RDP blank screen
  • Connection Between Client and Main PC (Server)
  • View RDP sessions
    I have this exact same issue as well. All searching for solutions have come up dry. Let's hope we get an answer soon, otherwise I need to force the students to install this on their PC and get me their IP
  • Video Display Quality?
    Is this project dead?
