  • Update veyon 4.1 to 4.3 problem displaying computer names on Veyon Master
    Hello I know that Win7 is no longer updated .. but I am a teacher and administrator of a high school. until last year the delivery of computers was still in win7 (license W10 downgrade to W7) I have about 1300 computers including about 1000 under W7 .. I paid a few hours to maintain the network (this is not my main job, since I am a teacher). the objective is to pass to W10 the whole computer park but it will be done in time ... because I do not have that to do ... (creation of accounts, software update, WSUS, server anti-virus ... impossible to migrate 1000 computers in a short time ... because I have some licensed software, the installation time is 2 / 3H per computer and in some sectors it is 2 or 3 software to install by machine ... I found a solution that suits me for the moment Fred
  • Computers 'blinking' in and out - state changes- on master
    Phxantom16P
    Same issue here. Seems to have started in version 4.3.4.
  • Authentication Failed or access denied
    Regards, I have exactly the same problem, There is no way for user authentication to work. I always get the error message. I want to use this authentication method without generating Keys. I am using Linux Mint 19.
  • Room configuration with Active Directory
    DreggerND
    @tobydox said in Room configuration with Active Directory: Once the rooms get listed properly switching to the room automatically should be working as well. An important requirement for this to work is that Veyon is able resolve the local computer to an AD/LDAP computer object (by performing reverse DNS lookup and searching for the computer name in AD/LDAP) and find the corresponding room. Hello Tobias! Is this limitation with Veyon still current or is version 4.3.3.0 now able to use sub OUs of an active directory? Right now our Active Directory is configured with sub OUs to splitt between notebooks and pcs. If it´s still current: What about the subscriber edition? Can you show where i can get more informations about it? Best regards from germany Norbert
  • Mass installation
    DreggerND
    Hey Laura! Are we talking about Windows Computers? Are they member of an Active Directory? If can answer both with yes it´s really easy: Veyon can be installed by using a script which can be used as a startup script. By default (you can change this too if you want) Veyon is installed under C:\Program Files\Veyon so it´s a simple if exist query in your startup script: if not exist "%Program Files%\Veyon" \server\share\installer.exe /S Important! For a silent installation you must use the /S switch with UPPER letter, otherwise it´s not installing. There are some more usefull switches /NoMaster Just install the client /ApplyConfig="\server\share\current.json" allows to specify your configuration I hope that´s usefull for you! Norbert
  • Challenge LDAP connectivty
  • Veyon on Zorin OS Lite version
    zorin os
  • Can i remote control a whole classroom at the same time?
  • Demo mode not working
    Assuming it's a problem with the built-in VNC server malfunctioning I installed UltraVNC on my master machine. Installed the service. Configured password and started service. Set Veyon to use External VNC server on port 5900 with the same password. Et voila - it works now. Somethings just not right with the built-in UltraVNC server.
  • Default Username and Password
    As far as I can tell Veyon just uses local authentication by default. So any local username and password will work.
  • Using two screens and a Beamer as a Teacher
    @mpschwe said in Using two screens and a Beamer as a Teacher: not sure on windows It uses a build in version of uvnc.com on windows
  • Lock Client Configuration
  • Lock Easily Bypassed with Second monitor
  • LDAP Browsing is super slow.
  • Does this thing work? What am i not doing right?
    jgordonJ
    I have the start of a blog on setting up Veyon that might help. https://www.oraclelinux.dev/2020/02/veyon-part-1-introduction-and-my-system.html I'm not good at this and it is a draft but any constructive comments would be welcome.
  • Imported config.json will not work, till manual activation
    kotteK
    The service is really restartet... I tried several ways. Restartet in services.msc Restartet in the configurator in the service tab Restartet with cmd Everything is done with an administrator or also with the system account. I also tested the access right in the configurator... By checking the username... Before press apply the user don't have the right to access, but the user group from AD is already set... After pressing apply and restart the configurator the same user can access. This can be repoduced everytime the config will imported again.
  • Can't login user (instead accessibility window appears)
    The first paragraph on changing the group policies
  • How to compile Veyon on windows platform?
  • UNC in Parameter "ApplyConfig"
    Are UNC paths working with the "applyconfig" command or should I first copy the config to a local path on the device? Cheers.
