  • Demo-ing to a computer not logged on
  • How to hide multiple master stations in one location
    Hello guys, I have the same problem when i apply ldap filter. Empty list of computer. Did you find a solution ?
  • Issues with Power On
  • Internet Access Control Settings
    @tobydox Yup! Gives me a direction to look in. Thank you!
  • Connection problems with Windows 10 pro.
    V
    Hi all, i have exactly the same problem. Unfortunately I can't downgrade to version 7.3 because my clients have Ubuntu 22.04 Jammy Jellyfish installed. Would be nice if there would be an update soon to lock my students computers.
  • Ask logged on user for permission on preview issue
    @Alefunshow Or for example to view the preview only when I double click in the icon and the user give me the permission for the session.
  • Impossibilità di connettere clients remoti
    @correlio Nel manuale c'è riportato tutto il necessario, comunque per potersi connettere deve avere l'indirizzo ip del computer dello studente e inserirlo nel configuratore della macchina master
  • Does Veyon has Web Interface?
    At the moment this is not possible. We plan to provide a web-based solution with Veyon 5 in 2023.
  • high CPU usage when on multisession
    @rpgmem i leave "veyon-master" blank on installation.
  • Share screen on 65" smart tv problem
  • Access to Master from Android tablet or Phone.
  • Screen lock at Logon Screen Windows
  • Tổ hợp Sun Riverpolis Đà Nẵng
  • Chromebooks
  • Windows 11
    @mmg-carlos Same thing for me, i install from scratch, and nothing works! Using a pc with ASTER multiseat and other for the teacher, and nothing works anymore on Windows 11
  • how to config demo mode?
  • Access control error & LDAP
    @ltsepp Found the problem.Wrong settings under object attributes User = sAMAccountNAme Group = member Computer display = cn computer hostname = cn That worked for me
  • Veyon for Redhat 8
    Unfortunately we do not have packages for Redhat 8 (since CentOS 8 is EOL) but I would recommend building an RPM file manually as described in the README.md file in the sources.
  • Interception Driver Uninstalling by itself
    I guess you enabled Multi session mode in the Service configuration page. When enabled, the Veyon Service uninstalls the Interception driver since it's known to cause problems in terminal/remote desktop server environments. If you do not need multi session mode, simply switch back to Local session mode. Otherwise the Veyon Service has problems with accessing the Interception driver so it tries to reinstall it manually.
