  • Veyon Master ab 4.9.x zeigt sporadisch keine Clients an
    V
    We have the same problem, sometimes the Veyon Service into clients PC doesn't start. To verify this, logon on unreachable client as administrator, run Veyon Configurator and try to start service manually. At moment we haven't found the cause.
  • Question about setting up a student laptop
    Hi, thank you for your answer, i submit an issue here : github _ veyon _ veyon / issues / 1033 (sorry i can't post a link)
  • 1 Veyon Master PC, 3 Private Keys and 3 Public Keys
    Hi! You can describe how you make this config? You set variable? And if yes, how to?
    V
    Hello, This is a Windows login configuration on non-Veyon PCs to modify. There should be no information from the previous user. Interactive login must be enabled : gpedit.msc Expand: Computer Configuration -> Windows Settings -> Security Settings -> Local Policies -> Security Options. On the right, locate and double-click the "Interactive logon: Do not display last user name" policy.
  • Public key needed on teacher's devices
  • Remote View/Control fix window size/position?
    Another temporary workaround is to use the custom computer arrangement to create a "gap" in the middle of the 4 computers we have selected for that individual display TV, that way only 1 instance of Veyon Master needs to be open. This looks like its the more likely temporary solution we'll use. (and for the demonstration, we'll often have the students name on the computer number in notepad in the middle). [image: 1743704158234-d8699514-7bfc-4c51-887e-b7cb90a6b4ee-image.png]
  • Linux Mint
  • Windows environment variebles in the path in "Run program"
    root0R
    @FrEmaVeyon You can "Start Application" using %USERPROFILE% environment variable. For this You need to start it using cmd: cmd /c start "" "%USERPROFILE%\program.exe" This will work
  • Help importing locations & Computers
    root0R
    Valid variables are %type%, %name%, %host%, %mac% and %location%. Various examples are given in the command help (veyon-cli networkobjects help import). from docs.. Construct each line as following - do not include header, do not separate with spaces Computer15;10.23.15.15;"Conference2" note the quotes 2. Go to "C:\Program Files\Veyon" open cmd in this folder command: veyon-cli networkobjects import "FULL PATH TO CSV FILE HERE" format "%name%;%host%;\"%location%\"" You should see [OK] on the command line Read the docs for better understanding
  • How to add Computers in batch?
    root0R
    issue 913 on github explains it - I cannot post any link Close configurator if it's open Create csv file where each line is like this: pc0;10.88.17.0;"class1" here pc0 will be visible in Master interface, 10.88.17.0 IP Address, but it can be hostname, last "class1" - note the quotes is the name of the location Once You have csv file go to "C:\Program Files\Veyon" open cmd there: command: veyon-cli networkobjects import "PATH TO YOUR CSV HERE" format "%name%;%host%;"%location%"" You will see [OK] on command line 4. Open Configurator and check
  • Demo on lock screen (no user is logged in)
  • Remote Classroom access
    No they don't have the same keys
  • ScreenLock from WebAPI and CLI
  • Why even use locations without LDAP?
  • URGENTE URGENTE GRAZIE impostazioni iniziali
    veyon con i pc collegati con wifi è un pò ballerino, per risolvere mettere ip statici e mac address in "posizioni e computers" in veyon configurator
