  • How to log on WebAPI ?
    Same issues when install veyon master on Windows 10. I don't know what's wrong, I already check the port already active. Try install veyon master on linux and authenticate it using Postman and it works. This is my solution until now
  • Windows 11 & Veyon not working
    @SipiFree I have windows 11 and it works perfectly fine, you could try to check if the service is running and the port is free. Use netstat to check if the port is used. If it's not try to reinstall Veyon and make sure IP is right. The MAC doesn't have to be right because it is for wake on lan.
  • suggestions for adding new features
  • Problems with Veyon-Configurator
    veyon-configurator QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root' Logger: "/tmp/VeyonConfigurator.log" is a symlink and will not be written to for security reasons 2024-12-06T10:23:11.405: [ERR] CryptoCore: failed to decrypt password! 2024-12-06T10:23:11.416: [ERR] LinuxPlatformPlugin: Received signal 11 2024-12-06T10:23:11.417: [ERR] BACKTRACE: /lib/x86_64-linux-gnu/libc.so.6(+0x3d1a0) [0x7ffb2de591a0] /usr/bin/veyon-configurator(+0x1d945) [0x56319b741945] /usr/bin/veyon-configurator(+0x22d70) [0x56319b746d70] /usr/bin/veyon-configurator(+0x129a1) [0x56319b7369a1] /lib/x86_64-linux-gnu/libc.so.6(+0x27b8a) [0x7ffb2de43b8a] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7ffb2de43c45] /usr/bin/veyon-configurator(+0x134b1) [0x56319b7374b1] 2024-12-06T10:23:11.417: [CRIT] Aborting due to severe error
  • Windows Server 2025
  • Students bypassing filtering
    Reviving this thread as this is the only one i can find on the matter, but i've been having this same issue, too. At first, staff would log in to veyon Master with their own account, but i realised that students being monitored by Veyon were able to bypass the Student Web Filter on our Fortigate Firewall because the firewall saw the teachers logon session on the DC and it looks like the teacher has now logged on and is assigned the profile. To bypass this, i have had to create a generic account for use with Veyon which is set as a student, so this retains the student webfilter, however i can see all the different entries from different devices on the firewall from this user. @tobydox said in Students bypassing filtering: the Veyon Server/Service on the client computers check the teacher's credentials by performing a temporary internal user logon with the teacher's username and password. However it does not initiate a real user sessions so I wonder why your firewall recognizes the teacher as being logged on Are you able to expand on this ^^^? Because the veyon user logon event shows up in the DC's event logs (which are monitored by the firewall to assign user sessions) and there seems to be no difference in this logon to any other domain user logon. The workstations are only checked for logoff events, as these don't appear on the DC. As far as the firewall is concerned, whenever a client computer is connected to, the logged on user has changed, as this is now the latest logon event seen on the DC for that device.
  • Package for NixOS
  • unable to receive the file because it cannot be opened for writing
  • Windows 11: fail-fast error and missing PC in main console
  • Veyon goes from "Running" to "Stopped" state
  • how to restrain access to Veyon Master to some AD groups?
    Hello, Thanks a lot for your answer!! I figured it out, I hadn't activated the User Groups with the LDAP Basic (this field was not there in the 4.8.3 Version). I can't believe I've searched for that long without noticing there was another new field to activate the User Groups in the General menu! I can now set the control access according to LDAP groups. Many thanks!
  • Update Slow Client Screens
  • Use Veyon without admin rights
  • veyon on Ubuntu
    @vlouvlou Hello, just seen your post and I'd like to ask, How did you solve this? I'm doing my first installation of Veyon in Ubuntu 22.04, followed these steps: 1.- Install Veyon in PC server, authentication with user / password so this will act as Master. Also installed NEtwork discovery addon to check for clients 2.- Install Veyon in PC client and start service with the GUI. The network discovery plugin is not able to find any PC, but I don't understand the solution you aplied to solve it. Could you help me? Thanks a lot!
  • Veyon master crash with "show current location only" (LDAP Pro Add-on)
  • WebAPI Option missing on Windows
    You can go to top menu and choose view->advance Then menu webapi will exists on bottom
  • install new .json using veyon configurator remotely
  • How can i find first login password?
    I have no password in my windows session
