  • custom shortcut
    Sorry but such a functionality is currently not implemented
  • I can't open websites from the teacher's computer
    V
    @javisky said in I can't open websites from the teacher's computer: there are only two possibilities of path That's really true
  • Some clients computers don't automatically start veyon service
    14
    4k Views
    V
    I'm sorry, no good news: [image: 1581490882199-veyon_service.png]
  • Mascara de subred 255.255.254.0
    Computers only have to be reachable via TCP/IP. If everything is set up properly and you can ping other hosts in the network, the netmask shouldn't matter.
  • 4.3.3 Multiple computer login not working
    MrCharlyM
    @MrCharly said in 4.3.3 Multiple computer login not working: Hello New here, just started using Veyon yesterday, I have it all setup and working to control 30 nodes from one admin machine. When I try to log in all of the computers using the "log in" button on Veyon Master the screens on the nodes flash and present the Windows login page but do not automatically login. Is there something else that needs to be setup in order for the to work? Admin PC - Windows 10 Pro Education 1909 Nodes - Windows 10 Pro Education, mix of 1903 / 1909 (Neither respond to this command) ![alt text](![image url](![image url]([image: 1581076554898-log-in-button.png] image url)))
  • Can't install on Win10 Clients
    MrCharlyM
    Try using the free version of PDQ Deploy, I was able to deploy the Veyon 4.3.3.exe to 30 computers, its really simple to use. When deploying just add the following parameters for a silent install and remove Veyon Master: /S /NoMaster https://www.pdq.com/pdq-deploy/
  • I can usse without IP STATICS
    10
    5k Views
    @Sanny Thank you very much, this is the solution I was looking for!
  • How to debug OpenLDAP
    jgordonJ
    This is what I have setup for OpenLDAP, if it helps. In OpenLDAP it uses multiple memberUid's for members of groups. [image: 1580553913022-ldap-group-membership.png] These setting seem to work with my limited testing and knowledge. [image: 1580553913353-veyon-env-settings.png] I changed the group member identification and filtered objects on the different OU's and then used the test to ensure I got back the right objects. [image: 1580553913172-veyon-advanced-settings.png]
  • keyboard and mouse problem
  • Veyon master interfacing copy/past to word 2019
  • centos 6
    You'd have to build binary packages on/for the according system. Please follow the instructions at https://github.com/veyon/veyon#veyon-on-linux to generate an RPM. I'm however not sure if all the dependencies (especially GCC 6 or newer and Qt 5.5 or newer) can be satisfied on CentOS 6.
  • can't download
    It's ok, the link for Veyon 4.3.2 works now
  • Clients unable to connect to master during demo
  • Clients are getting black in demo mode
  • Viewer: Strange Effects + Low Resolution
  • Veyon Master takes host name but shows as diferent pc.
  • Cannot pass authentication, already tried docs, googling etc.
    jgordonJ
    What access group is the public key set to in the configurator? I believe it defaults to root or administration group. Does the second user belong to the admin group on the 2nd pc?
  • Configure Veyon via cli to use authentication keys
    jgordonJ
    Actually, I realised that I was using the defaults keyword and that was always showing me the defaults and not the actual values. Stupid mistake. Using veyon-cli config list I can see that the following key Authentication/Method changes from 0 (logon) to 1 (key file). So now I can run veyon-cli config set Authentication/Method 1.
  • Replace authentication key error
  • Demo mode sluggish
