  • 1:1 Windows Laptop Management with Network Discovery
  • Installation defaillante
  • Uso di più veyon master su rete Windows
  • IL LOG IN NEI COMPUTER REMOTI NON FUNZIONA
    La password è corretta!
  • Demo and Login are not working.
  • networkobjects clear and import: access denied
    Hi, Thank you for the answer. Indeed, by putting a UNC path I no longer have the problem of access denied. It's a total success of the working class !
  • Bypass Screen Lock
    Y
    We've noticed this problem too - we thought there should be an option to disable the client keyboard/mouse input whilst you are using remote control. The same use case applies to lock mode, but this remote input disable isn't implemented as a function in Veyon. The VNC backend should support these functions already - so can the Veyon Client and Master make use of these?
  • LOCK
  • Veyon 4.7.5 Bug Fix and LTS
  • user session debian 12
  • webapi
    Hi, Parsing veyon conf for something else, I noticed this : WebAPI/HttpServerEnabled=false It's the default conf (I didn't touch anything about this). Maybe modify this parameter should help (if you didn't yet). (I didn't try, I don't use webapi... Just an information I found by chance and I thought could help you ) E.T.
    I forgot something in my previous post : VERY IMPORTANT : The table in your nft file must be named like the file (the name you gave in veyon-configurator) too, or you won't be able to deactivate blocking from master. As example, if you declare "myfile" in veyon-configurator: On clients, you must put a file called myfile in /etc/veyon/iac/firewall/rules.d/, containing your rules, and the table in this file must be called myfile too : table inet myfile { Don't forget to activate InternetAccessControl/UnblockOnServiceStart=true in veyon config, this is the best (only?) way to be sure internet is available for next users, without any need to do anything (automatically deactivates blocking on clients when the user logs out, or reboots). Finally got all this running like I wanted to... Thanks to Todybox for his precious help (and job on Veyon, of course). E.T.
  • Image on laptop only filling two thirds of the screen
  • No access to ubuntu 22.04 in samba ad environment
    I answer myself. The problem is wayland : I deactivate it and now veyon master can access the ubuntu workstations
    Ok, here is my update. The short answer is "Yes, it works, the configs are applied correctly". The long answer is, this is how I have done it for my specific case: check the lines in this bat file for the silent installation phase: https://github.com/danielemaddaluno/chocobuzzi/blob/d6dea35148e6a4c59f85cb6f087c50c0610495bf/installer_informatics.bat#L98C1-L107C63 then you can find the "install_veyon_*.bat" files inside of this folder: https://github.com/danielemaddaluno/chocobuzzi/tree/d6dea35148e6a4c59f85cb6f087c50c0610495bf/nochoco
  • using vpn at veyon
  • Veyon and Dynamic IP
    Thank you for your answer. What are the names you are referring to? Because I tried the ones that are present in the LAN (the identifier names of the PC) whitout any success. If I wrote the names of PC, should I insert IP too?
  • problem with demo
    11
    does anyone know how to save the websites? where the info are recorded?
  • Different colured icons
    Anyone please? Mods - do you read these posts?
  • Ctrl+Alt+Delete
