  • Peripherals do not work normally
  • Mobile laptops and wifi - doesn't work
    Hi, I think network discovery addon should be able to partially do that, no ? But it doesn't only rely on veyon's conf. Your master(s) should be allow to communicate with those wifi networks, which depends on your network conf (infrastructure and master's conf). Of course, if laptops are student's personnal computer, I think it's not a good idea to ask them to setup a software on it, which gives you remote access. More than an ethical issue (already sufficient IMHO), there could be a legal problem. Regards E.T.
  • Using Veyon with Azure AD devices
    Hallo, ich habe das selbe Problem ... ich rolle Veyon über Microsoft Intune aus, leider funktioniert die automatische Übernahme der Konfiguration (Schlüsselauthentifizierung) nicht wie in der Dokumentation beschrieben ... - am Client kommt das immer als Anmeldeauthentifizierung an - und somit ist kein Zugriff möglich (Rechner wird rot angezeigt). Wenn ich händisch die Konfiguration und den Schlüssel importiere, dann geht es ... ist aber keine Option ... Ich bräuchte eine klare Anleitung, wie die automatische Übertragung der Konfiguration und des Schlüssels über Intune funktioniert ... ich teste schon Tage herum und kommen nicht weiter Bitte um Hilfe!
  • How to disable automatic clipboard transferring?
  • using non-domain joined devices
  • Service veyone is not starting error 1068
  • mass login does not work
    21
    @Carlo That solution isn't good in my case, because I'm not always present in the laboratory and I can't always log the students.
  • AD Setup Assistance
    DC=domainName,DC=lan Where the domain is "domainName.lan"
  • Maquinas com acesso via Remote Desktop não exibem a tela
  • Demo Mode not working after a while
  • Can connect but get only a blue screen
    The headless VNC plugin will always shot a blue screen only. You have to use the x11vnc backend. If you switched from Wayland to X11, it should work. If not, what errors can you see in the VeyonServer log files?
  • Problema funzione Login windows su computer remoti
    @Tommaso said in Problema funzione Login windows su computer remoti: Buon giorno ho un laboratorio con 30 pc windows 11, nella procedura di login remoto soltanto alcuni pc ricevono tutta la sequenza di caratteri nel campo Utente e Password, gli altri non compilano completamente ma mancano diversi caratteri, ho già provato ad aumentare nel configuratore il campo (Simulato l'intervallo di pressione dei tasti) fino al massimo possibile ma la situazione non cambia, Qualcuno mi può aiutare questa funzione mi è essenziale per la gestino del laboratorio. Grazie. ~translation from google~ Good morning, I have a laboratory with 30 Windows 11 PCs, in the remote login procedure only some PCs receive the entire sequence of characters in the User and Password field, the others do not fill in completely but several characters are missing, I have already tried to increase the field in the configurator (Simulated key press interval) up to the maximum possible but the situation does not change. Can anyone help me? This function is essential for me to manage the laboratory.
  • WoL does not work - LDAP Basic
  • How to make students don't see the Veyon window
    Presumably your projector is just duplicating your current monitor, correct? Set your projector to EXTEND your desktop rather than duplicate. Then you can show whatever you need to on the projector "monitor" and keep things you do not want students to see on your actual monitor on your desk.
  • Log in function Ubuntu
